Finish spray gun -help
Gary Smyth
>Spray guns. HVLP vs. conventional, and gravity feed, compressor capacity, and 1.4 tips? What the? So here�s what I have and I�m asking for advice. I have a 2 gal Emglow non HVLP conventional compressor with a 125 lb pressure max. I want to use the spray gun for cabinet exteriors and interiors, lamp parts, and chandeliers. Nothing over the size of 4� x 8�-- 90% smaller jobs. For wood I will be spraying lacquer and interior latex and enamel paint, and poly. I will be using thinned outdoor paint and engine enamel for the lamp parts. Come to think of it a fender or two could come into play in the long term. If it means two dedicated guns, that is possible if they operate and clean easily. A smaller CFM is preferable to the alternative--something under 12. I went to an auto body shop to find out about guns and they showed me a Sata gun but the cost is out of the question. (I�m only in the $20-$70 range) They showed me various tips and said 1.4 would be ideal. I don�t understand what that means. They told me to stay away from Wagner and that�s OK by me but I need a crash course. I�m looking for recommendations for a this weekend purchase and a Sunday test. I�d favor refilling a cup rather than slinging around a big cup underneath the gun and (VERY IMPORTANT) I want to be able to point the spray up and down, without spit not just horizontal. So what have you got to say? Help please.
Re: Finish spray gun -help
Re: Finish spray gun -help *LINK*
>With all your criteria, I have the feeling this may be a "you can't get there from here" situation. However, I suggest that you put your question on Jeff Jewitt's finishing forum to get much more input from Jeff and others there. Follow the link, click on forum, and go from there.
mm
Homestead Finishing
I'm on my way
Gary Smyth
nailshooter
>Wow.. I have about 3k invested in equipment to get the complete package you are requesting. I am not trying to be a jerk here, but $20 - $70 can only get you in the door with with a lower quality Taiwanese knockoff gun.
This is kind of like asking for one saw that cuts circles well, has a 10" depth of cut, has easy repeatability with a quality fence, rips clean enough that no trip to the jointer is needed, and will handle tiny pieces to sheet goods safely. And it needs to be cheap, not just affordable.
I would try to get the best gun I could for the dough like some of the Sharpes if I were on a budget. These are supposed to be a pretty nice gun with good support, and they almost fall into your budget, just a littl over. Check the link and you will see the ones with he 1.4 mm tip. This is the one I use the most with paint, enamels, lacquers and polyurethanes, YMMV.
Don't buy a cheap gun and expect it to really perform well. Worse, a lousy gun will sour you on spraying, making your quest for really good finishing impossible.
Watch the CFM requirements on any of the high pressure or HVLP conversion (non turbine) guns. Like the shop vac ratings for horsepower, these guys stretch their gun requirements pretty far. No matter what the box says, you can almost bet you will need a third more CFMs from your compressor.
Good luck!
Robert
Sharpe guns
Jim Dillon
>Gary,
I'm no spray gun expert by a long stretch and didn't want to initially invest a bundle for a tool I didn't anticipate using that much. And I know the Wagner brand makes some people's blood boil, but - having said that - consider the gun described in the link below. It doesn't meet all your criteria and is a bit more expensive, but seems to be very well made for the price. I have a hot-dog 1 1/2 hp compressor to run it. Good luck.
Jim
Wagner Conversion Gun
Thanks to all
Gary Smyth
>Thanks to all for taking the time to respond. I understand that I was hoping to do a lot on the cheap. You've convinced me to back away. I've lived this long without spray capabilities so in spite of my wish to rush, another two weeks or so for intensive reading and product comparison will be time well spent. Like most of you, I think, I wanted to press on using what I have for the job and get a good deal on something resembling a decent gun (or two), but also like most of you, I'm not going to settle for an inferior result because I'm not prepared to listen to experience and, at the very least, start right. Thanks for the information. As it turns out I have several new suggested reading references including Andy Charron's Book "Water Based Finishes". I'll start there. Also the web has been helpful. DeVilbiss has a thirty page book online "ABC's of Spray Finishing" and Jewitt's site info is helpful also. Thanks again to all. It's time I head back to school!
