Cutting melamine??
Cutting melamine??
Cutting melamine??
>I may be tasked with making a dry erase board. Any thoughts on how to cut the melamine coated board without much chipping? As it will be a large board, I will be using a circular saw.
It'll be in a frame, so some chipping is allowed.
Re: Cutting melamine??
mike mcnerney
>On the table saw we use a 80 tpi triple chip, look for something similar in you 7 or 8" saw. say 50 or 60 tpi. good side down. Or if you get it at the borg ask them to cut it & see if thta's good enough in side a frame with a 1/2" rebate you should be fine.
mike in ottawa
Andy Lincoln,In Dearborn MI
>JL,
After some extensive testing last year at work we built a 4'x8' dry erase board using the $10 white,plastic coated paneling from HD.To give the sheet rigidity we laminated it to a sheet of 1/2" birch plywood that we had cut a bevel hanger/french cleat out of to cleanly attach it to the wall.We then trimmed the edges in hardwood to give a finished look.
Andy
Neal in San Jose
>If an absolutely clean edge is important, use the circular saw to cut slightly (1/8th or so) oversize, and trim to final dimension with a good straight cutting bit in a router. Use a straight edge clamped to the melamine to keep the router going straight. Note that the edge of the melamine will now be very sharp, and you may want to just "break" the edge with a fine file or some sandpaper.
Re: Andy, NGHC...
>the "local" lumber company (35 miles away) has 1/2" double sided melamine coated plywood for $38. As I will need oak to "frame" it as well as build a frame, I'm going there to get materials as opposed to the borg.
Agree. Don't use melamine
Ellis Walentine, Host
>The melamine coated products (flakeboard, fiberboard) have a texture that you might not like as a dry-erase board. The glossy, smooth coated hardboard that Andy mentions is the go-to material for this application, at least in my experience.
Re: This is a smooth textured coated ...
>product that has a "glossy" texture. It is slightly different from the typical coated stuff. I've seen it and it compares to the glossy finished tempered stuff that I think Andy is referring to. They have other melamine coated board there that have a "pebbled" texture. I'm not getting that.
That's sort of why I'm asking about cutting it.
Ah, I see
>That's a new one on me. Back in my contract furniture days, I ran across some "curtain-coated" hardboard products that were similar to what you describe, but they were not melamine. They were similarly difficult to cut without chipping, though. In those days, they were using ceramic-tipped blades on the beam saw for that stuff.
Let us know how it works out. I'd also like to know if your material wipes really clean or leaves ghosts of your markers? And, where do you get the stuff?
Re: NGHC... *LINK*
>North Georgia Hardwoods Center.
I have no idea where they get it from. They are the distributor.
