Help, I'm A Rock
Help, I'm A Rock
Help, I'm A Rock
>In the last stages of a walnut kitchen bar-height table which uses Dark Emperadore marble tile (12x12) for the top. Have filled the joints with colored epoxy, and have cleaned off the excess resin with solvent. I still have a few streaks and a few errant scratches in the stone that I want to bring up to an even polish. Anyone here done this and if so, what did you use to clean up the stone surface?
Thanks.
mm
Re: Help, I'm A Rock
>I haven't done marble, only granite tile pieces. I used a slurry of aluminum oxide and water in decreasing grit sizes (80 - 600). You could probably use rubbing compound also.
Re: Compound
>I have Meguire's, but I'm a bit concerned about defeating the factory sealer applied to the tiles. Suppose I'll just give it a shot and hope for the best.
Thanks
