Granite
Ron
>I am helping a friend at work install a granite countertop what kind of a bit do you use to drill for the holes for the faucet thanks. RON
Granite
Ron
Diamond edge circle cutter w/water
Re: Granite
Pete LaBelle
>I'd have the granite supplier do it. Those are holes pretty close to the edges and it is also an expensive piece of material for you to learn on.
Diamond drills & water are the way to do it. Not cheap though. A diamond core drill that I purchased a couple years ago, 3/8" diameter, cost $42.
