Jewelry making question
jeff
>Hi all
Not woodworking, but you never know.
I need to find a Jewelry maker who can answer some questions about making jump rings.
So, if your into jewelty making or a wife or friend, please pass this on.
In helping my wife (the jewelry maker here) she has a jump ring maker that's giving us a problem we're trying to solve.
You or they can email me at: spirerjd@verizon.net
Also, anyone know of a good forum for jewelry makeing like this one for woodworking?
(I make the jewelry boxes she sells.)
Jeff
Re: Jewelry making question
>What is the problem? She has a jump ring maker, is that correct? Plier type or just a mandrel?
Stephen
Re: Jewelry making question *LINK*
David Barnett - SW Florida
>It would help to know if your wife has the original "Jump Ringer", the "PEPE Jump Ringer System" (a lower-priced but adequate knock-off of the aforementioned sans the panoply of accesories), or the "Koil King", which has many advocates.
As I mainly make hundreds of small diameter fused jump rings at one sitting from 20 to 29 gauge fine silver (.999) or 22k gold wire, both very soft and deformable, I prefer to use other methods to size and sever my rings from the mandrel, but I'll try to help if you can describe the problem in detail.
Probably the very best thing is to refer you to the archives of the "Orchid" mailing list where you will posts which will almost surely address your exact concerns and likely give a exact solution. You'll find no better resource for jewelry making online. Check out the "Bench Exchange" while you're there. Fascinating.
Orchid/Ganoksin
The Problem is
jeff
>She has this unit that you wind the wire onto a mandrel.
Then, you remove the coiled wire and set it into a metal cutting/holding jig.
The cutter uses a Foredam tool with a blade and alignment holder to then cut the rings thru a slot in the jig.
You set the cutter (running) into the jig and slide it from right to left to cut.
Usually the cutter stalls about halfway thru cutting.
Does this mean you need to go faster, slower, or need a more powerful motor? Or maybe just the right "touch"?
You can't restart the cut, as then the rings get scored a second time or sometimes just scramble up.
The cut ones work and look nice, but there seems to be alot of waste.
In making jewelry, my wife uses alot of these rings, so shes's trying to reduce the waste factor.
Thanks for any help.
Jeff
The question is why is it stalling....
John in NM
>You do have to have a light touch with Foredom tools, but if its all held in a jig, the only reason I can see for the stalling is perhaps the blade is binding due to built up metal chips. Perhaps the feed is too fast, though then I'd expect it to stall almost immediately.
In the mean time, she could probably finish the cut with a frame saw, not as fast or tidy, but she could at least use all the rings.
John
Re: The question is why is it stalling....
Lee Schierer - McKean, PA
>It sounds to me like the rings that have been cut are binding the cutter. If the rings that have already been cut twist sideways, they would tend to pinch the cutter. If you can prevent the rings that are already cut from moving as they are cut free from the spiral wrap around the mandril, perhaps you can eliminate the binding.
Lee
Don't give up... *LINK*
>Jeff said:
"She has this unit that you wind the wire onto a mandrel."
"Then, you remove the coiled wire and set it into a metal cutting/holding jig."
"The cutter uses a Foredam tool with a blade and alignment holder to then cut the rings thru a slot in the jig."
"You set the cutter (running) into the jig and slide it from right to left to cut."
All three of the commercially marketing jump ring makers I mentioned (and presumably more) work this way (some better, some less so), so I'm still not sure which you have.
Is it this?
http://www.ottofrei.com/store/product.php?productid=10076#DetImage
Perhaps this?
http://www.sfjssantafe.com/itemstable.phpGid=101&ItemSet=Forming+Tools&DepId=tools&ot=&at=
Or maybe this?
http://www.desiredcreations.com/howTo_TLKoilKutter.htm, which I mis-identified as "Koil King". It's actually "Koil Kutter". My apologies to Dave Arens, its inventor.
Then asks:
"Usually the cutter stalls about halfway thru cutting. Does this mean you need to go faster, slower, or need a more powerful motor? Or maybe just the right 'touch'?"
Then explains:
"You can't restart the cut, as then the rings get scored a second time or sometimes just scramble up. The cut ones work and look nice, but there seems to be alot of waste. In making jewelry, my wife uses alot of these rings, so she's trying to reduce the waste factor."
Firstly, all three jump ringers benefit from cutting lubricant. Secondly, feed rate (and direction) is all-important. Feed rate depends on composition of metal (alloy, or pure), wire gauge, hardness of alloy, amount of work hardening resulting from drawing/annealing cycles. Consistent technique in wire handling and winding tautness should be a goal, as should facility in easing into the cut, continuing the cut to the end at consistent rate with temperate pressure until cutting is complete. Stalling at the beginning or end of the cut will cause problems as will stalling anywhere along the cut.
Experience with a particular wire (incl. wire gauge, alloy, mandrel size, hardness, handling details, and so on) should be recorded in a notebook, esp. at first. Skill is involved. Some take to it intuitively and seem to make automatic adjustments. Others may experience a more challenging learning curve. After a short while waste should become minimal, however, so don't give up.
As for your Foredom. It should never be allowed to stall. Release power immediately should that occur. Any Foredom (or similar flex-shaft) has more than enough HP and torque to do this job. Upgrading won't be necessary. Also, residue or chips is unlikely to cause problems as it might in other metal machining operations. These saws are very thin. A 'ring jam' is most often caused by lack of lubricant, wrong or inconsistent feed rate, too much pressure, or twisting of the saw blade.
Again, the Orchid list addresses these problems and their solutions in their forum archives and tutorial/articles section and should become your go-to place for goldsmithing, stonesetting, and jewelry making questions.
Orchid/Ganoksin
To sum up...
>Oil up.
Speed up.
Lighten up.
And keep it up.
As I said, I make a LOT of jump rings, and all the gold ones are made from a 22k alloy from the wonderfully pure (.9999) Canadian Maple Leaf. Nothing quite like melting down a perfectly good 24k one ounce coin, adulterating it with silver and copper (the alloy is equivalent to alluvial gold), beating it on an anvil, rolling it over a wire mill, pulling it through a drawplate, fusing into jump rings before finally bending and weaving them together.
My thing is replicating ancient woven loop-in-loop chain and granulation. I hope our Friends To The North will forgive me for defacing their coinage, but this is what it's all about for those smitten with my particular proclivity.
Beautiful
Dan Donaldson
>I can't even imagine the work that goes into one of those.
Thank you to all
jeff
>A great help.
I've passed all this onto my wife, including the forum site.
It's great to get the help that this forum always gives.
Jeff
