How smart is my computer?
Lee Grindinger
Lee Grindinger
>I'd like to record an internet streaming radio program that is broadcast at a time I'm not able to listen. It comes in too early for me. The broadcast is played on my Window Media Player. My computer is always connected and on. This machine is a PC, Windows XP.
Is there a way to do this? The program is broadcast on Q95 from Dominica, it runs from 7 to 9 local time which is two hours ahead of me. It's a local political show called Hot Seat.
So, oh great gurus, can I do this?
Lee
Re: How smart is my computer?
Ken Garlock, Collin County Texas
>Hi Lee.
For a start, open up your control panel, and click on "Scheduled Tasks". Click on 'Add scheduled task' and that will start a 'wizzard' that will guide you through the steps to select a job and time for it to run. The job is selected from a list of possible programs already installed on your machine. You will want to look for a program called 'audio capture' or something like that. After the task is defined, you will want to open the properties of the task and fine-tune the options; things like wake up the computer to do the job at the specified time.
Addy protocol: I have never done this specific task. Others can fill in the details and point out my errors.
Good Luck, it sounds like a neat idea.
Ken
Tom
>Audacity will record from your sound card. And it's free. Whether or not it can be used with windows scheduler is another question. I don't know the answer. The newest version of Audacity has a built in timer, exactly for what you want. It is a beta version though. I'd use the scheduler several times in advance to make sure it works, and also make sure your pc doesn't hibernate. It may or may not wake up. See link below:
http://audacity.sourceforge.net/download/features-1.3-k.php
Curly Smith
>If you're willing to just record vast amounts of stuff and then find what you after the fact then one of these free programs might be of use as you could just find the station, tell it to record and then walk away:
Mp3 Stream Recorder v2.2
MEDA Audio Recorder 1.5
You might be able to get Windows Scheduler to work with one of the above if you're able to set a default station. However, if you want a program that you can schedule then you'll need something like iRadio ($40) as described here:
Internet radio station ripping
Falberg saw Co
>You can set up AudioEditDelux timer to do just that, but you'll need to "tune in" to your station and leave it streaming until you can turn it off again. If you can program your scheduled tasks to open that station link at the same time, you're in business.
Lee Grindinger
Thanks folks
Lee Grindinger
>I'll give these suggestions a try,
Lee
