rush weaving
rush weaving
rush weaving
McKay Sleight
>I have only done rectangular rush weaving before so I am unable to direct a student as to how to weave a seat that has the sides shorter than the front and back. The front is longer and we have accounted for that by weaving the front corners and attaching the ends. Do you have to do the same for the front and back until the same size as the shorter sides is achieved? Thanks in advance.
Re: rush weaving
Re: rush weaving
George@Colonel's Workshop-Havefrtown PA
>Good Afternoon McKay,
I'd continue weaving all four panels until the sides were closed up and the space between front and back panels was decreased to a oblong slot. At that point I'd weave the last two panels until the slot was closed. I usually inserted triangular cardboard pieces to bulk out and give form to the corner weavings. I disliked to handle rush because it tore up my hands and made wrists ache badly. I farmed out that work to #3 son, who got quite good at it. Good luck.
George
Re: rush weaving
Re: rush weaving
>Continue weaving until the sides are full, then weave from front to back. On a square seat it ends up all four corners converge in the middle of the pattern. When the sides are shorter then the two side points converge and form a straight line at the tuck under in the middle, running side to side.
Stephen
Re: rush weaving
The others are right, just keep
Don Henthorn
>on filling out the sides and then go front to back until the panel is full. If it were me I might want to do it over as I see a lot of space between the different cords. Beginners especially find it difficult to keep uniform tension on the rush as they work and the job does not turn out as smooth as it should be. Here is a pic of a seat as it should look.
This one is still a little rough as it hasn't been smoothed with smoothing paddle nor sat on with a nice warm, moist human bottom which also helps smooth out the surface. It does take some practice to get it right. I used to do three to four a day when I was younger and working regularly.
