burning bore box bit revisited
brad kansas
>Well, I replaced the 27k/rpm Porter Cable cable router with a Porter Cable variable speed in my table and turned the speed down to 12K. Following Ellis and one other responder's information regarding the burning point being at the point on the bit where it curves up to 90 degrees, I reduced the depth of the cut and presto, only insignificant very slight browning. Discoloration occured at the slower speed at progessively deeper cuts, but not the dark brown to black as with the faster router - yet, still unacceptable. Therefore, slow router speed and shallow depth interact to minimize discoloration. Moving the material very slowly across the bit promotes burn but normal safe movement does not. Running a router at 12k isn't nearly as scary as 27k. Thanks for all the earlier tips.
Brad
