OT Painting Questions on Rental house
>I've been working on a rental property. The tenants left it in pretty rough shape. I got to practice my proficiency at patching holes. I am ready to paint, I think. The house was painted by former tenants with multiple pastel colors and apparently never cleaned and they smoked.
I have washed the walls with Simple green. Is that enough, or should I go over it with TSP? I need to do the ceiling anyway, so TSP or Simple Green?
I was considering a coat of Kilz on every thing as a primer. Some of the existing paint has some gloss to it. Is Kilz a good idea? Will it adhere to the gloss? Is it necessary?
I am thinking I will "Kilz" everything, including the trim and then top coat with flat latex on the walls and semigloss on the trim. Good? Any better ideas?
Re: OT Painting Questions on Rental house
Go with a higher sheen
Nat Robison
>I would go with at least satin on every surface. You just can't clean surfaces painted with flat as well as you can with higher sheens. I had some soot on a flat-painted ceiling and I couldn't clean it with anything. I finally painted that ceiling in satin.
Priming is never a bad idea and I believe Kilz says it will stick to most things but spot sanding the shinier spots wouldn't hurt.
Re: Primer
>Barry,
Since cost is a consideration for any landlord, I'd suggest a primer rather than a stain-kill like Kills. While flat is harder to wash, increasing the gloss of the coating will reveal more and more wall defects, so egg shell or satin may be the farthest you should go, although woodwork should be gloss or semi-gloss.
The other thing with Kills is that it seals the wall surface where it's applied. If you do spot treatment, you'll then see texture differences because the top coat is effected by the different porousity of the wall surface. DAMHIKT
mm
Re: OT Painting Questions, not a landlord
Glenn Madsen near San Francisco
>But we did raise 4 sons, and had a lot of painting to do over the years. And I had a really good friend who was a professional painter, who taught me what works.
Primer is additional work, but worth every cent and every hour. I use Zinsser BIN, because it seals in the smells from the smokers, and I don't have to deal with that any more. Clean well, then prime well.
I use eggshell level finishes, because they clean well. Here in CA, the walls are skip-troweled, and the surface has the right amount of sheen. Flat doesn't seem right anymore, and needs repainting far more frequently, in my experience.
We also found that using a good quality, heavy bodied paint meant fewer coats, and better looking results. The costs out of pocket were quickly overwhelmed by the savings in labor and rework. I use Kelly Moore, because I have for 30 years, but there are several other really good brands with which I've had success. And Behr from HD, purchased right, has worked out well for some applications.
Being a good landlord is a challenge. Keep at it!
Painting Questions, from a contractor
nailshooter
>As a contractor, I think Glenn's response it dead on. I have "freshened up" or totally gutted too many of these things to think about missing a step.
Cleaning the walls with a good detergent, then a good rinse is a great idea. I repainted the inside of a house that was about 2500 or so square ft a couple of years ago that had two smokers in it for about 25 years. The walls didn't need repair, just paint. It was a dark house inside, and our halogen lights put out so much light when we turned them on that the walls looked fairly light (as in unstained). So >I< decided that I didn't need to prime.
After the smoke leached through three coats of the top line Glidden semi gloss, I stopped the job. Went back in and primed everything with Zinsser Bullseye, two coats, and waited a week. Nothing bled through. Put on two coats of finish top coat and it was done. In seven coats of paint.
Now when I paint around kitchens, or where smoker live, I wash as needed to get the tar off the walls and cabs, but mostly just shoot a couple of coats of Bullseye and then paint.
I agree too, that you should never scrimp on paint. A few dollars more a gallon can make a real difference in quality. I only use top of the line, or the one below it, never contractor grade unless it is for "one of those" landlords with frequent turnover.
For newer or nice homes, we use satin on the walls, and semigloss on the trims. That's pretty much the norm around here. But for landlord stuff, I always paint everything with semigloss unless requested otherwise. Even if the landlord doesn't like the shiny walls, they all love the increased wear and scrubbability.
Robert
Kneale Brownson in Northern MI
>I usually wash my rentals walls/ceilings with Spic 'n Span with just a dash of Chlorine in it. No experience with Simple Green. Only use TSP if there's a problem like mold. I usually prime with Zinser BIN so everything's uniform and topcoat with the next-to-best satin. I go over trim and doors with semi-gloss.
Jim Dillon
>Barry,
Rental properties are always tough calls as to how much work to put in and at what quality level. Given the differences in gloss (and probably texture) levels, I agree that priming everything can't hurt and the work goes fast. Certainly with drywall work, I'm now on the side of priming everything to even the appearance of the final coat(s). I use the Zinsser product and have had good luck. My 2 cents.
Jim
Murphy's Oil Soap........
Basil
>....is a good product for removing 'smokers' damage. It removes the smell pretty good to and is easy on any wood paneling, kitchen cabinets etc..
Start with the proper mix in warm water, wipe it on at the top with a well soaked rag and in a few seconds watch the brown stuff run to the floor.
Re: Painting Questions, from a contractor
Mark Nowicki
>Another vote for Zinsser. It will even cover up a smell left behind by a decomposing body. DAMHIKT.
Mark
From a painter...
Jason Roehl in Mulberry, IN
>You need to determine what you spend vs. your target rental market.
I paint about 30 or so rental units per year, most of those in about 2 weeks every August as I live near a college town. (Our company paints 150-200 rental units total per year). Those units that go mostly to students get less attention than those that are in the quieter parts of town.
First off, we don't have time to be washing walls, it's just not generally necessary, even with cigarette smoke. We scrape any nasty stuff off, if there are cobwebs, a quick broom around the ceiling and down the corners will take care of that. Then we use a no-shrink, lightweight spackle to fill anything up to about the size of a quarter, scraping the spackle flush with the wall--no sanding. Anything larger or excessive (like dart boards) incurs an extra charge, and we'll use 5- or 20-minute setting-type joint compound for those (we'll sand those). Next, we'll use rattle-cans of Zinsser BIN (white pigmented shellac, or I've switched to clear shellac--no visible overspray) for any ink or water stains, or any other stain that we think might not cover in 2 coats. In units with painted trim, we try to get the landlord to go with one paint on everything, as it's about half the time to paint (and half the cost). Generally, that is an egg-shell. Depending on how good you want the walls to look, you could take your roller and go over all the spackle spots first, then roll everything (better, not as quick), or paint everything, then touch-up the spackle spots with the roller (look at the wall at a low angle to look for "dry" spots, looking toward a light source is best). Most of the time, we roll first, then cut-in becuase many of the units don't get fully painted, so we don't paint more than we have to, and we charge accordingly.
As for paint, an off-white eggshell is best. Cleanable, and it doesn't look diry as quick as a straight white. Even better is a factory-mixed color (we use a lot of Glidden Ultra-Hide Antique White Eggshell). We roll with 18"x3/4" rollers and cut with 4" brushes. If the paint leaves lots of spatter on your arms, it's junk, get a better paint. If we come across a ceiling that needs to be painted and hasn't been before, we spray it. Most ceilings are stomped drywall mud here, we don't want those chunks breaking off in our roller. If they're already painted, the peaks don't tend to break off as easily, so they can be rolled if necessary. For a 4 BR unit, I figure on about 3-4 hours (no ceilings), and if it's not too bad, and I have to get it done yesterday, it can be done in as little as 2 hours. I should note that we use the same paint every year, and have quite a few landlords using the same paint.
Okay, I've rambled on enough. Let me know if you have any questions. I just think too many people "overdo" painting, making it more work than they need to (but those are the ones that often keep us in business!) It's not rocket science.
Jason
Thanks every body!
Note on BIN
Dave Bair, Eaton Rapids, MI
>The fumes can be a problem, especially in an enclosed area like a closet, a toilet alcove, or even a closed-in corner, especially near the floor. Have a good fan available or a rated respirator.
