The camera I'm working on needs some refinishing. There are a few spots of crazing(?):
Anyone able to ID the finish type from the look of the peel? The camera was made in Rochester, NY, somwhere between 1907 and 1925. I'd rather not strip and refinish everything if I can figure out how to resolublize what's there (as in shellac) or just remove the finish coat.
>Put a small drop of alcohol in an inconspicuous spot. If the finish becomes "tacky" and soft, it is shellac and can be "re-flowed / re-coated" using fresh shellac / alcohol. If it doesn't, try a spot of lacquer thinner, same scenario, the finish is lacquer re-flow, re-coat with lacquer / thinner. If those don't work - It's probably a varnish of some sorts and will require striping - That has exhausted my knowledge of possibilities - other's more experienced may have other ideas.
>I don't know the value of this piece as an antique but the general rule of maintaining the value of such items is not to re-finish. Just clean the existing finish and leave it alone. If there is no antique value and you just want a neat old thing to display then do whatever you want.
I doubt there's much intrinsic value to this camera as an antique. If there was, I ruined it by fixing some of the wood problems. ;^)
This camera is to be a complete user. I want it to look nice, and to last another ~100 years, but it's going to be my primary field camera by the time I'm done with it. Need to cobble a 4x5 reducing back together first...
>Using the alcohol test will identify shellac but shellac is not a very likely finish used on wooden cameras. It's possible that it is NC lacquer (developed right after WWI and used extensively for furniture). To test for lacquer dab on some lacquer thinner and see if it dissolves and gets sticky.
Most likely it is a varnish finish. That was the most used finish for high quality items at the time you estimate for construction. And, from the pictures, it looks like varnish looks when the finish has deteriorated. The finish yellows and adhesion fails as moisture gets between the finish and the wood. There is no way to "rejuventate" varnish. It must be removed and then recoated.
With the high degree of failure, I would recommend first scraping off the flaking finish then sanding off whatever is left. When you are down to bare wood, recoat with a good non-poly varnish. Something like Waterlox Original Gloss would be appropriate. Waterlox is a phenolic resin/tung oil varnish as were many of the varnishes 100 years ago. It is a dark varnish that looks very good on darker wood. Behlans Rockhard is also a traditional phenolic resin/linseed oil varnish that would also be an excellent choice.
