Motor trouble follow-up
Denis Ch�nard, Orl�ans, Ont.
>A couple weeks ago I posted a message about my air compressor quitting while filling the tank. I did a number of checks and here's where I stand now:
- pressure switch is still on
- power goes to the motor
- motor remains absolutely silent, no humming or anything
- I had both capacitors (start and run) checked, and they are up to spec
- I checked for continuity at the capacitors leads (before putting the capacitors back on), and I get continuity in both cases, so it seems the windings are intact
I would tend to think that the starting switch is not of an issue, since the motor quit while running. The only item left to check is the thermal protection switch, which I am kind of reluctant to do as it involves opening the motor. But then again the other option would be to take the motor off the compressor and bring it to a shop, which I'd like to avoid if possible. anything I should be concerned about when removing the motor end cap?
Any comments/suggestions are welcome...
TIA,
DC
