wooden braclets
wooden braclets
wooden braclets
James A. Minor
>I have never turned a bracelet, but have bought a book on them. It says to use a 3/4" x 4" blank. Does it matter which way the grain runs? Can you cut a 4" limb and use it?
Thanks,
Jim
Re: wooden braclets
Re: wooden braclets
>James if you leave it thick you might get buy with it but I would turn it by gluing several layers of wood together with the grain running perpendicular to each other. You are basically making plywood. If you cut off a section of limb and turn it you have weak grain all the way around.
Re: wooden braclets
check this out.  *LINK*
http://www.woodturner.org/vbforum/index.php?
Re: wooden braclets
Re: wooden braclets *LINK*
Charles Smith
>James, you might get more responses if you post your query in the 'Turning' forum. Nevertheless, there was a good demonstration of making a wooden bracelet at the March meeting of the Greater Vancouver Woodturners Guild. You can read about it from their newsletter at the link below. If that is not sufficient to explain how it is done, I took a couple of pictures of the bracelet at the meeting and can email them to you. I think that they look great, and they certainly got the eye of the women who were present that evening.
Charles in Victoria (who plans on making some for his daughter)
Greater Vancouver Woodturners Guild April 2007
Re: wooden braclets
Re: wooden braclets
>I have very little experience turning bracelets. I watched on a Turning Show on TV and decided to make one. Measured one I borrowed and tried a 2 5/8" hole. Seemed about right for an adult. You want the hole to be as small as comfortable to go over their hand.
My first attempt was out of a walnut scrap, about the size you described. I chucked it and cut the hole in the center. IF I recall, I actually used a woodworm screw. At some point I expanded the chuck jaws into the nearly finished bracelet. It flew apart.
So, I think the idea of laminating them is important. Not only for your safety while making them, but to make them tougher and durable enough to wear.
I agree with John about the limb idea. It would be weak and you should post this question on the Turning Forum to the left.
Re: wooden braclets
Re: wooden braclets
James A. Minor
>Thanks for the help.
Jim
