Sawmill owners - - which metal detector?
Pete LaBelle
>Guys -
I am part of an antique tractor club and we operate a sawmill at our annual show. After hitting numerous nails & bolts this past few years, I've convinced the club to buy a metal detector.
Any recommendations ?
Thanx............
Pete
Re: Sawmill owners - - which metal detector?
Re: Sawmill owners - - which metal detector? *LINK*
dwr
>Pete,
Here is a company I will be looking at for my own sawmill needs. They have everything from mega to hand-held.
Good luck!
Dave
Metal Detectors
Keith Newton
>Pete, I have a WM Lt 15, and use a woodwizard detector for my needs. It is hand-held, and scans a path about 12" wide and up to 3" deep. When I start to see color in the wood, then use it, It is pretty good at locating whatever is in there.
It would be nice to be able to have one of those like the above poster linked to, but I don't saw enough to afford one of those.
Some things to consider. If you are going to get something really powerful, you need to use it away from the mill, and then not having ever used one of those, I wonder how well you can pin-point where the object is in the log, or do you just cull the whole log?
When you get a lower power such as mine, you may be able to use it on the mill, so long as, you can stay away from the carriage, and not get a reading from metal in the mill. You obviously couldn't use a high powered one after the log is on the mill, otherwise it would be fooled by metal in the mill.
dwr
>Pete,
You obviously don't need to buy the one on the Home Page I posted previously. As I mentioned, they have a handheld unit, just browse the Product Tab. I was told the handheld unit will scan and detect an 8d up to 15" deep with adjustment for sensitivity. It runs around $900. I planned on mounting it on the front of the saw-head and connect a light/alarm so I could stop the saw before reaching the affected area. Then grab the unit and zero in on the spot.
No affiliation, just another person doing what you do...
Dave
Hand-Held - Probe 2100
