Cordless drill battery question...
John Ergle in SC
>I've read in the past about folks sending the battery to their cordless tools off to have them rebuilt, but I've never had the need 'til now. Is this cheaper than buying a new battery, and who would you recommend?
Thanks
Re: Cordless drill battery question...
>I called a local Batteries Plus type place and they said they could rebuild my Makita batteries. Drove to the other side of town with the batteries only to be told "Oh!, those are the ones we can't open". Needless to say I was not a happy camper.
The point is there are local shops that may rebuild yours, but check and double check before you make the drive.
I ended up sending mine to Primecell that was mentioned here on WC often. They rebuilt them and upgrade all four to the Nickel Metal Hydride, including adding a thermal sensor. I paid about ten dollars more per cell for the NiMH up grade over NiCad. They still cost about 2/3 of new and were supposed to be better. They seem to be fine, but I have not run any really scientific tests.
Now that I know a little more, I probably would not pay for the upgrade to NiMH. Turns out they last longer in use, packing a little more power into each cell. OTOH NiMH bleeds down faster when not in use than NiCad. In my hobby shop I might use tehm all day one day and then not touch them for a month. I have two rechargers and four batteries. Charging a couple while I use the other two is not a problem for me. Just not sure I "got" much out of the upgrade.
I paid shipping one way, they paid it the other.
If you have the skills you can buy individual cells and rebuild them yourself. I did not want to try that.
Another consideration...
Jason Roehl in Mulberry, IN
>Not all chargers can properly charge both NiMH and NiCd batteries, so it's often best to rebuild with whatever the original type is.
Here's another rebuilder who hangs out mostly at another woodworking forum:
http://batteryrebuilders.com/
Jason
Joe in a Cleveland suburb
>John.
I've used primecell a number of times now for my Porter Cable 14.4 battery packs. I do the Nicads. It costs me $45 for the 14.4 rebuilds - not including shipping the battery to them. A lot cheaper than new PC battery packs.
They seem to last a couple years. Give or take for typical weekend warrior stuff.
FWIW.
Joe
second Jason's recommendation
Curt Harms
>BatteryRebuilders.com did a nice job on my P-C drill batteries. I had questions about the charger-sent it to him-he checked it out-found it to be O.K. Excellent service.
Curt
