Why did you delete it from your PC????
>Don't bother to answer that. I think I know why. You probably thought tht you had them on your PC and copied the to your MP3 player so you didn't need then in both places. I normal way to think.
And if you used Windows Explorer to COPY the MP3 files from one device to the other, then you should have had no problem.
But if you "syncronized" the devices using the WMP software or the SanDisk software (which is another good way to do it) then everything was problably fine until you tried to delete the songs from your computer. Then it saw you delete them from the computer and since you synced the devices it would have syncronized the deletions to your MP3 player.
Perhaps not logical to your way of thinking, but definitely logicial in the way "syncronization" is intended to work.
What you need to do (quickly) is undelete the songs from your computer or go and re-rip those CDs and get them back on your computer and then sync your devices to have them back on both devices.
Now, please bear in mind, there are alwyas a half dozen ways to do the same, or almost the same thing on a computer. So I could be wrong in my assessment of the situation. But if you ask "where did you go wrong", it's quite possible that your intent of deleting the songs from one device but leave them on the otehr device is contrary to what the "sync'ing" is going to do.
Hope that helps.
Happy Woodworking!
