Need advise on kitchen cabinet refinish
Alan Tolchinsky
Hi All,
I have a kitchen in my new house that has cherry cabinets with flat panel doors. The only thing my wife and I don't like about them is that the finish has hardly any sheen at all and they have a lifeless look to them.
I tried waxing them and that helped a bit but they still look bad. How would you go about applying a finish with a little more sheen. I'd be happy with a satin finish or even slightly more sheen. Do you have to apply shellac first to bond the new finish to the old? This is not a large kitchen so I'll just do what I have to to get the desired finish. I don't have any spray equipment. How about spray lacquer in a can? Thanks for any ideas! Alan
Re: Need advise on kitchen cabinet refinish
David Yoho
>Alan,
You didn't say which wax you tried. It's been my experience that some waxes shine a little glossier than others. Did you clean the outer surface before waxing? You said new kitchen - is that brand new or new because you bought another house? If not brand new, I'd suspect there might be a layer of film that should be cleaned before doing anything. TSP is good for cleaning and removing grease.
Personally, if the finish wasn't damaged (i.e. - peeling, chipped, or cracks), I'd go for something easier than applying a new clear topcoat (like you've already tried) first. I'd try wax, but in this situation my wax of choice would be one like Briwax. After it's set a bit, I'd use a power buffer to buff it to a high shine. This would be much easier than re-coating and might provide the shine you're after.
David
Jim Dillon
>Alan,
I agree completely with David on this one. We have old cherry cabinets in our kitchen and it is amazing how much grime can accumulate on them over years, especially in the stove area and around the knobs. You don't notice it as much with darker cabinets, but it is there and tenaciously stuck on. Nowadays, I would use (or see below) a gray synthetic pad and one of the grease-cutting products on the market (Simply Green, Murphy's Oil) or TSP. Then use an easily applied wax to bring back a little luster. Sure easier than refinishing IMHO.
Oh, I just remembered and dug out a copy of a WoodCentral thread on March 18, 2007 regarding cleaning old furniture. Al Stokka and Bill Tindall gave some good advice, including a cleaning formula by the late Sam Simpson. You might look that up too.
Jim
>I agree with the others and wanted to add that I don't think I would attempt adding a top coat with a spray can. I do not have a spray room any more and have tried to apply finishes to a number of projects with spray cans. The finish in the cans has about 1/3 the solids (actual finish) of the stuff you brush on or what might be sprayed with a good spray gun. Just don't think you will get the "build" and gloss you want and don�t think it will be durable. Plus you would have to be extremely thorough cleaning the cabinets.
You might look at the option of taking the doors and drawer fronts to a cabinet shop or refinisher in your area and have a professional finish applied. That would just leave you with the face frames and ends and perhaps you could wax and buff them.
Alan Tolchinsky
>Thanks David,
Yes, these are brand new cabinets in a new kitchen. I used Johnson's Paste wax but your recommendation of Briwax plus buffer sounds like a winner. I'll try that first. Thanks so much! Alan
Alan Tolchinsky
>Thanks Jim, Barry, and David,
Those are all great ideas. I will try David's idea of using Briwax first and see what happens. I appreciate your input on this. Thanks again. Alan
PS, on wax
>I was thinking about this. You have already waxed these. I THOUGHT that if they were waxed you would have to do a REALLY good job of removing the wax before you could apply more finish. (This was based on my experience with wood floors and the crap people put on them when cleaning and waxing, HAS to be removed before more urethane can be applied) It might be possible that you could put lacquer on them without as much effort over wax, but I don't really know. Ask Russ or someone with more experience. Either way, you already have a coat of wax on them, so you might as well give another coat of wax a shot.
Not Just To Be Contrary *LINK*
>But I don't regard wax as a preferable finish for heavy-use surfaces like kitchen woodwork. It is easily attacked by water spots (wax attacts water vapor and dulls), food acids and solvents, and is easily scuffed. It tends to be a high-maintenence finish.
Since your cabinets are new, they are most likely finished with an acrylic coating that has a fair degree of hardness, even if the mfgr. tended toward the cheap side of things. This should provide you with a reasonable opportunity to rub out the finish to a higher gloss without adding anything to the surface.
I would first remove the wax you put on with naptha and a rag. Once cleaned of the wax residue, I would suggest you use a automotive polishing/cleaning compound like Mequire's No. 3 Fine Cut Cleaner either by had or with a mechanical buffer with a gentle pad using a minimum of compound to bring up a better gloss on the existing coating. Care here is the watchword as you don't want to cut through the coating. If the compound doesn't get you to where you want to be, it has the advantage of being "paintable" whereas wax of any kind would need to be removed with solvents if you decide to recoat the items with a topcoat finish.
If the rub-out doesn't please and you decide to apply a topcoat finish, use one of the quality acrylic waterbornes, NOT that junk at the paint store or Depot etc. I'll suggest one of the Fuhr finishes like their #355 satin varnish which can be applied by hand with very good results or Fuhr's new #3200 coating. For more information on these, check with Jeff Jewitt on his website at the link. Jeff's finishing forum will also get you a lot of feedback where the contributors are not merely a bunch of spray-gun junkies.
Good Luck
Fuhr at Homestead
Re: Not Just To Be Contrary
Alan Tolchinsky
>Thanks a lot Mark. That is so much great information. I'm going to try your ideas after I try the wax method. Thanks again.
I refinished an old kitchen
>If the dullness is in the finish material (flattener) rather than due to a "rub out" of the finish surface, you may need to actually remove the old finish.
Be warned that this is a REALLY time consuming and detailed job, especially for raised panel doors.
If it were me, I'd avoid that unless it was really ugly. If I did do it, I'd take the doors to a refinisher to get them stripped.
Been there, done that, got the tee-shirt, hat and belt buckle!
