>I'm trying to plow 1/2" and 1 1/4" very shallow several inch grooves in quarter sawn white oak using a Woodcraft core box bit. I'm using a two horse non variable speed Porter-Cable router in a router table. I can't stop burning both ends of the groove regardless of how quickly I remove the wood or how shallow I make the depression. I'm trying to sell what I'm making but need to get rid of the burn.
>I don't know what tools you might have to adapt to this, but what I have that works well is this.
I have a made a little right-angle disk sander. I have a set of punches from 1/2" to 2", that I can punch my own sanding disk out of the 6" adhesive back ones for my random orbit sander. I have a set of cheap diamond bits for die-grinder, or dremmel with 1/8" shanks. I chose one about the size of a penny with rounded edges, then coated it with contact cement. When the contact cement is dry, it makes a good resilient rubber base for the small sticky disk.
For this, I usually use a right-angle air-die-grinder, and about 120 grit. When you get the hang of it, you can sand the burning off in just a few seconds each, without having other problems that show up in the finishing stages.
If you have a problem following my description, send me an email, and I will take some photos of the tools, and email them back to you.
>I might add that bits burn when they get dull and/or when the radial relief grind on the carbide tip is too shallow at some point along the profile. The relief grinding angle is applied by a computer-controlled five-axis diamond grinding machine. There are a lot of variables in the process, but the better bits generally have a more carefully controlled relief angle to minimize burning. Steeper relief angles can also mean the bit dulls faster. Core-box bits are a very fussy profile, where grinding is critical. I have not compared Woodcraft bits to others such as Whiteside or Freud or CMT or Amana, but you might have better luck with a more expensive bit, at least in this profile.
>I have a 1 1/4 or 1 1/2" Core box bit I bought at Woodcraft to route slots also. I had the same problem with the burning. Don't remember the brand. Dremel sells little abrasive disks (?) that look like they are made out of a Scotchbright pad or a nylon abrasive pad. About an inch or less in diameter and a 1/4" thick. They mount on one of their small mandrels. I made a jewelry box with a bunch of burned slots and used these abrasive discs to clean them up. They wore down fast but, worked great. They came from the orange borg and were fairly cheap. I believe they were in two grits, one medium and one finer.
>I was in Lowes this morning and looked at he Dremel display. The Items I was talking about are No. 511E Buffs and come as a pair. One fine and one coarse. They were $3.97 for the pair.
>I agree with the dull bit and lack of relief on the cutter grind comments Ellis made. You can also use the router bit as a scraper. With the power cord disconnected, set the bit at the right depth and rotate the cutter by hand so the cutting edge cuts against the burn area. Also, when you reach the end of your cut immediately reverse direction and turn the router off while continuing to move the bit along the groove you already cut. This should minimize the burning.
Sometimes I have had luck by sneaking up on the end of the channel I'm cutting with the core-box bit (actually round-nose bit in my case). In essence, I cut until I am, say, 1/16 inch from my end mark and stop. Then I take a stance and adjust my grip on the router so I can cut that last 1/16 inch and reverse direction as quickly as I can. This approach seems to minimize the burning. Sometimes it works, and other times just a little burning remains that I can clean up with sandpaper. The downside is that I sometimes overshot my pencil mark a tad, but that is better than than the onerous sanding. Might be worth a try. Good luck.
>The sides on the Woodcraft core box bits are 90 degrees after the initial curve. The burn is at the point where the bit curves up to the 90. I think you've got it.
>I'll try the scraping method. Sounds easy. I do back off the router when I get to the end and lift the piece off aroung the middle of the groove. But it doesn't help. I use a router table so turning the router off while the piece is still on the bit would be too ackward to execute without messing it up.
