THE WOODRAT IS BACK!
Woods that go with Zebrawood
Jaosn
>I'm designing a kitchen island and I'm trying to decide what woods to use. The only part I'm sure of is I want to make the top with 8/4 zebrawood. For the legs, shelves, and rails I'd like to use two woods... one to reflect the lighter parts of the zebrawood (the sapwood part?) and a darker one (such as walnut?) to emphasize the dark parts of the zebrawood. What wood(s) would you recommend to go nicely with zebrawood. I'd prefer to do a simple tung oil finish as I'm quite new to woodworking and want to keep the project as simple as possible... ie; no staining. Thanks!
Re: Woods that go with Zebrawood
Complementary woods (long)
>Everybody has his or her own take on what woods go well together. It's part of the fun of designing your own projects. Sometimes two or three woods just seem to click together, for no obvious reason, but I think it has to do with three things: Hue, value and texture. Density and durability may enter the picture for other reasons, but hue, value and texture are the big ones IMO.
Wood hues tend to be blends of red, yellow, blue and black. Browns are all mixtures of the three primary colors, in different proportions. Blue never appears by itself, but it is responsible for purplish hues, as in mahogany and purpleheart. Cherry is red-brown with a fair amount of yellow warming it up, while walnut is brown-brown with a little purple if it is new and especially if it is air dried. White oak and English oak are also on the brown-brown axis, with yellow overtones; red oak has red and yellow overtones.
The value dimension has to do with lightness. White oak and walnut are both brown-brown, but the oak has a higher value, so it appears lighter. Tans and browns are all on the same brown spectrum but with different values. By combining woods of different values, you can make a design more dramatic or more restrained-looking.
To my eye, colors with similar hues complement each other better than those with dissimilar hues. Walnut looks better with oak than it does with cherry or mahogany, unless you are staining or otherwise altering the hue.
Texture is another dimension that is also subjective. This has to do with the "decorative" aspects of the wood, such as the grain patterns of open-pored woods (versus the more uniform grain of diffuse-porous woods like maple and cherry), or the prominent ray structure of lacewood or quartersawn white oak, or the spots of birdseye maple or the crazy swirls of burls.
Texture can also involve color differences; zebrawood and Macassar ebony are both stripey woods, claro walnut often has reds, golds browns and blacks juxtaposed, and ambrosia maple has dark streaks as a result of fungal activity.
"Figure" is another component that adds to the texture or visual interest. To me, figure is a measure of the chatoyance, or shimmer, that you see when the wood grain ducks in and out of the surface. Maple, satinwood, eucalyptus, sapele, makore, koa and other species often show high figure, in various patterns. They may be curly or fiddleback, flamed or quilted or mottled or blistered. It can be subtle or dramatic, and it can be in combination with some of the color and grain features I mentioned above.
Adding yet another layer of variability to this complexity, wood colors and values are subject to change due to oxidation, ultraviolet light and other environmental factors, so you have to think down the road a few years to what the piece will look like. Purpleheart turns brown, African padauk turns a dark brownish burgundy, maple yellows, walnut lightens and yellows in the sun but not in the shade. Etc., etc.
Don't forget to factor in the decor of the space you are building into. Architectural woodworking is subject to a lot of different constraints from freestanding furniture or treen, which can be moved to different surroundings. If your decorating theme is bright and light, you might not want to add the visual weight of a lot of walnut. If the decor is subtle (or even if it isn't), you don't want to add too much visual interest with your secondary woods, as the zebrawood itself will provide plenty of visual interest all by itself.
Sorry for the long-winded lecture, but I thought it would be good to have this sort of conceptual framework for choosing complementary woods. In the case of zebrawood, there is very little figure, but the texture is very dramatic with the narrow, contrasty stripes. I like Peruvian walnut, which is very dark, or one of the American walnuts to complement the brown-brown stripes of the zebrawood. I think the low values of the walnut (the darkness of the wood) frame the mixed values of the zebrawood well, without being too contrasty, as they might be if they framed a light-value wood like ash or maple. If you like a lot of contrast, you might pick a gold or ginger-ale colored wood to "pick up" or complement the gold hues of the zebrano. Mulberry would be an excellent choice for color, but the texture may be too heavy, and besides, you'll never find it at a lumber yard. Maple with a wash coat of a tannish dye stain might work for color, but the texture might be too flat. Birch with some figure might also be nice. Satinwood would be a knockout, depending on how much drama you can stand. The color is just right.
So, I suggest you cogitate on some of this stuff and see if any revelations pop out at you. You might want to visit the Woodfinder Wood Library to see some images of different woods and find suppliers that carry them. Whatever you do, I suggest you make up some samples of the combinations you want to use and finish them with your intended finish. Then, you and your spouse or customer can see in advance what the combination is going to look like.
Let us know what you decide.
Ellis Walentine, Host
Re: THANKS Ellis
Larry Clinton At Frankfort (Central)., Indiana
>I have a pretty good stock of wood, and wanted to intermix some on up-coming projects. But I really am concerned that I don't have enough knowledge to make the right choices. I have some very nice figured Cherry - One full tree about 20" in diameter that was air dried several years ago. I have a lot of air dried walnut - some with beautiful color. I also have a good stash of WO, Poplar, some Black Locust, and Sycamore. I wanted to use the Cherry with another wood, Walnut doesn't sound like a good choice from your statements. Sounds like you would recommend a Cherry - White Oak combo? Wonder how Cherry and Black Locust would work together. The last piece I built with BL had a lot of chatoyance - the wood color & figure changed dramatically from different viewing angles.
Excellent Information
Jim Shaver - Oakville, Ontario
>Thanks Ellis,
Your post is one that O am saving for future consideration. Colour and texture are often characteristics that I consider when selecting my materials. Your direction for reflection here is a great starting point for consideration in any project.
Thanks,
Take care,
Jim
Combinations
>Hi Larry,
White oak and black locust both have a lot of yellow in them, which picks up the yellowish cast in aged cherry. (Fresh cherry, of course is more of a salmon color; the brownish yellow color develops over the first couple years.) That said, both of those woods have texture differences with the cherry, as both have strong grain patterns and white oak may have ray patterns as well. Plus, cherry has a reddish flavor that neither of those woods have, so it is not a marriage made in heaven, IMO. If you want a light wood, I'd look at ash if you want bold grain or maple if you don't. Darker woods that go well with cherry tend to have more red in them, like aged padauk or mahogany. There are a lot of people who use cherry with walnut and see no problem with it; it just doesn't resonate very well with me because of the red vs brown clash.
There is some danger of analysis-paralysis here, and my preferences are based on my sensibilities (or lack thereof :-). If you like the combination, that's all that counts. I just wanted to give you some things to think about as you consider your options.
cherry and sycamore
Tom Sontag - St. Louis
>I have had luck using QS sycamore in a cherry project. In fact, I'll be putting finishing touches on such a project this weekend. The darker red rays in sycamore match up with cherry very well IMO.
Thanks Ellis for the tutorial. You ought to make it an article. Or take excerpts from this thread and do it. I know, more work.
Re: Thanks again Ellis
>I printed out your thoughts on combinations, I really appreciate the information. I have learned long ago not to trust my instincts - I think the "right brain" in me is dormant. I prefer a good photograph to Picasso. So many things that look good to me don't appeal to others. i try to understand the basics so I can attempt to make things that people enjoy. I like some complex furniture and joinery but really don't care for most of the extravagant styles like Chippendale. Do like some of the French Provincial - guess I'm just odd.
Wow!
Joanne Adler in Pt. Pleasant, PA
>I was going to say "Maple and Walnut", based on color and maybe how busy the grain is on those. But I wouldn't have had all of the Professor's excellent comments and rationale. Thanks for the question. Ellis, thanks for the wonderful answer.
