Squaring up to my problems....
Rob Hix - King George, VA
>Hey all,
This weekend I built a small frameless cabinet that, when done, will be my sharpening station. To break down the plywood into smaller chunks I used a saw guide and my circular saw. No matter how hard I tried I could not get the cuts square. My longest square is only 6" long, and squaring with that is almost impossible.
Question is, what about using a T-Square or a drywall square. I am not sure if either one will be accurate enough, but I know they will better than what I had this weekend. I have two jobs coming up which will be mostly plywood, and I really need to get this worked out. Can someone help with tool suggestions and/or techniques for squaring up the clamp-on guide?
Thanks in advance,
Rob Hix
Re: Squaring up to my problems....
Ray Binnicker
>Rob,
I can feel your pain. There are devices that make your chore easier and more accurate. I am in the house and the item is in the shop and I can't remember the name, but it is simply a clamp that clamps on the plywood at your premarked location (they come in different lengths, also)and you simply run your circular saw along its edge. They are as accurate as your layout marks. Another is simply a good straight 2x4 clamped on at your lay out marks. You should be able to get pretty accurate cuts, as long as you are satisfied your saw is doing its job.
Ray Binnicker
Larry Clinton At Frankfort (Central)., Indiana
>I never use a square for a clamp-up guide. Sheets of plywood as they come from the factory are cut pretty darn accurate as far as square. I use the "factory edge to do all my layout using a good steel tape measure. When you say "break down" the plywood - I am understanding you are making the final cut on a table saw? In that case, measuring from the factory edge and adding your "cleanup cut waste" is quite easy. Mark all your cuts prior to making the first one. You can mark your "rough" cuts and your "finish" cuts both if you want. I have a Unisaw with the 52" Beis fence so I normally just wait till my son is available and we do all the cutting on it. When I do use a clamp guide I break the material down 1/2" over or so, When doing the final cuts I always run the factory edge (when one is on the material) against the fence first, 1/4 or so oversize - then cut off that edge for the finished dimension. I make my cross cuts using my sled.
Squaring the saw guide
>There are several methods to squaring a saw guide. Here are 3:
Usually plywood is very square in my experience. If the sheet of plywood is square, you can measure from one factory edge on both sides and get square marks very accurately. To test this, measure the diagonals of the corners. Make sure they are identical. To mare really sure the plywood is not a trapezoid, measure the 2 pairs of opposing sides to make sure they are the same length - though I have not personally found a trapezoidal piece of plywood, but I have gotten plywood which was not accurately square.
Another method is to draw a large right triangle with the dimensions proportional to 3-4-5 (where 5 is the hypotenuse) this is easier than trying to measure an equilateral one with a factor of square-root of 2. This will be a good right triangle and be square.
You can always get a large builder's square from the Borg - I have 3 and all of them are quite square, though I have heard of lots of people getting un-square ones. Make sure one edge is very parallel to the plywood side.
Jim Dillon
>Rob,
A 6 inch square is a little short for achieving the accuracy you want. A solution depends on how much you want to spend. A framing square would be better. So would the drywall T-square you mentioned. The clamping devices that Ray mentioned are made by Tru-Grip and are called Clamp 'N Square for something like that. But that option is a little more expensive and you still need to really square it up to your edge. A homemade cutting jig would also work well. Cut yourself a nice flat piece of 1/4 inch masonite (or similar material) say 12 inches wide and as long as you need. Then glue a dimensioned 1 x 4 to one edge of the masonite. Then, using your contractors saw, butt the edge of the saw against the edge of the 1 x 4 and cut off the excess. You now have a great rip guide. Now, using your T-square, mark your line and then line up your masonite edge to the line, clamp it down, and let her rip!
I saved the one option for last and it doesn't cost a cent. Remember Pythagoreans theorem from high school trig class. That is the one where the squares of the legs of a right triangle add up to equal the square of the hypotenuse. So mark on the edge of your board the point where you want to cut the board. Measure over exactly 3 feet, make a mark on the edge. Then swing a partial circle onto your board 4 feet out with the center of circumference at your original point (where you want to cut the board). Then swing a partial circle 5 feet out from your 3 foot mark on the edge. Where the two partial circles cross is 90 degrees out from your original point. Draw a line from your starting point through the intersection and cut to the line. You can vary the length of the legs, but must adhere to P. theorem. Good luck.
Jim
Throw the square away.
Ray Thompson - Middletown,IN
>Actually you don't have to throw it away, just use it to make your initial layout then put it aside and measure across corners to get things squared up. Make your adjustments and check across corners again, when satisfied make your cuts.
Ray
You can also try this ...
Jim Moore
>Take the factory edge from another sheet and clamp it to the sheet you want to cut, placing it at such distance that you can use it as a guide for your circ. saw. Sounds primative, but works quite well if you don't have a table saw handy.
3,4,5 or 6,8,10 etc
Robin Corell in Atascadero, CA
