Leaning stack of oak - problem?
Stephen Kirk in Quakertown, PA
>While reading the posts below about drying cherry, I remembered that over the winter one of my oak stacks starting getting a nice lean to it. The boards still look straight and flat, they are just leaning. If it doesn't look like it'll fall over, is there any need to unstack it and straighten them out. Things started out straight, some I'm not certain what made them start to lean. Maybe as the boards shrank up a bit.
BTW - Now that it's warm and dry, I don't any visible signs of drying problems and I'm looking forward to cutting into some boards come June/July and see how they dried. Then it's off to find some more trees, or maybe even get an Alaskan chain saw mill.
Re: Leaning stack of oak - problem?
Tom Sontag - St. Louis
>I doubt your boards will be affected but you might want to pin down the problem. Did the ground/foundation settle? The whole stack should shrink kinda evenly (unless you have a dominant wind from one direction), so I'd be curious just to avoid any future issues.
