Help w/Delta Miter Box 34-080
Kevin Rabenaldt
>I have a 20+ year old Delta power miter box, the old cast iron one, that I need to service the armature. To open the casing I have to remove the belt and the arbor shaft. I can not get the pulley off of this shaft. The schematic shows that the pully should slide off and I tried everything. The shaft is theaded under the pully but on close examination it appears that the pulley is not threaded. There is a key way also, but I have stuck a wire throught it and there is no key (schematic does not show a keyway or key).
Anyone worked on one before and know how to remove this pulley?
Kevin
Re: Help w/Delta Miter Box 34-080
Kevin Rabenaldt
>I found the answer to my problem. The pulley is on a tapered shaft, like a drill press I would guess. To remove you need to wedge something behind the pulley and the housing. I used a chisel that had a tapered body. After a few whacks with this, it came loose. Though I would share in case someone ran into something similiar.
Kevin
