THE WOODRAT IS BACK!
Slope to concreet patio
ernie miller
>what is the ideal slope to put on a concreet patio to get positive runoff away from the house? is 1/4" to the ft to much? I was actualy thinking more like 3" over 14' will that be enough? I hope to have it covered eventualy
Re: Slope to concreet patio
Re: 1/4"/10' will flow water thru pipes and gutter
Al Crandall (N.E. of Indy)
>1/4" to the foot is good for concrete. If you are extra careful you can get by with a 1/8" to the foot. So your 3" in 14' would probably work. The problem with less than a 1/4 to the foot is that little ripples and inconsistancies in the concrete will "hold" water.
Re: Slope to concrete patio
Jim Moore
>A 1/4" slope per 10' is typical for drains because you want the "water" to move, but only so fast. If it moves to fast, it will not carry the solids. I would recommend at least a 1/4" slope per 10' for concrete, but for anything else, I would recommend more along the lines of at least 3/8" to 1/2". The idea being you want the water to drain off of the concrete as soon as possible. The longer is sits on the concrete, the more damage long-term, the concrete will receive. I've been told that in parking lots, concrete is typically sloped at a rate of 2% and blacktop, which is more pourous, is sloped at at least 3%. But I'm no expert at that.
