stickers for bandmilled cherry logs
peter bunnett
>I am wondering :
1.How long I can let cherry logs sit before I mill them to 1.5 and 2 inch thicknesses?
2.Is Mdf a suitable material for stickering outdoors undercover.
3Is it foolhardy to use oak stickers(due to tannin)
4 . Other than wood is there another device Plastic maybe that wood be an economical stickering device. Thanks for input. Pete
Re: stickers for bandmilled cherry logs
Paul Waddle
>You can use any non staining wood or plastic for stickers. I would sticker the boards immediately after milling. I would not plane until air or kennel dried. For the two inch stuff,you'll have to wait a couple of years for air or kiln????
Wood starts loosing moisture as related to the rh,sometimes it will worp overnight,so better git to gitten'. pw
The sooner the better. There is no advantage to waiting and you might suffer losses. Days or a week or two, not months. Wise but not necessary to seal the ends with something like paint or Anchorseal (UC Coatings) type stuff. If you paint the ends you can color code the paint to keep up with which Log/tree the wood came from.
Not the best. Tender and brittle in small sticks, breaks easily and does not do much to support he stack. Also might acquire moisture either from the wood or from the environment and swell up, upsetting the stack.
3Is it foolhardy to use oak stickers(due to tannin) Probably Ok if it is at least semi dry and the sticks are small. Wide stickers encourage sticker stain (mold) by retarding drying.
I doubt you want to pay for them. "Economical" is the operative word here. I don't think you can find anything more economical that wood.
I made thousands of stickers from wood I bought at Lowes from the bargain bin. They sold me a pickup load of "white" wood for about a hundred bucks. I used a thin (.1") blade and ripped it by the mile. Made all of mine .7 X .7" (half the thickness of the "two by" stuff, less the blade kerf)
Go to WoodNet.com for more info.
You want the stickers to be very consistent so the stacks can be level and neat. Various thickness of stickers cause the stacks to undulated and warp the lumber. Mine were a little thin, perhaps restricting airflow. I put box fans beside the stack for several weeks while the initial moisture came out. This is both simple and very complex. Good stacking encourages proper drying but can not save every board. Bad stacking can ruin it all.
like he said
Tom Sontag - St. Louis
>Barry nailed the important points, but in answer to your first question, cherry keeps in log form pretty well. Sitting in shade a little off the ground cherry logs can keep for a year or more, although there is no advantage to waiting. Sawing promptly is always best.
As for stickers, dry and consistent are the two primary criteria. Cheap and durable are plusses too. I would not use MDF.
Robin Corell in Atascadero, CA
>I use cypress for most of my stickers. I cut them 7/8 square and not always from dry wood. I have used pine and even some redwood, which like oak has a high tannin content. the redwood leaves a slight sticker stain on some woods but it dosent go very deep and is removed when the wood is planed. I prefer the cypress or redwood because insects don't like either.
I have a friend with a Lucas mill and he cuts 3/4 stickers from the same log he is milling boards from. Another friend uses the cheapest fence boards from the local box store and rips them into 3/4 strips. From my experiance the material and size of the stickers is less important than the spacing and the foundation. I have atached a pic of part of my wood pile. I start the pile with a sticker between the 4x4 and the first board. I have had good results with this method for almost 15 years.
I used to think that milling as soon as the tree was cut and quickly end sealing was the only correct way to mill wood. in the last couple of years I have come to think a bit diferently. I have milled several logs that were down for several months with little degrade. I am currently milling a lifetime supply of walnut logs that were removed last August and they are milling and curing just fine. The walnut logs do have their root ball still atached and I think it may help a bit, also walnut is one of the best behaved woods to cure.
I will add here that I have zero experiance with cherry and each type of wood is a bit diferent with some being so diferent that it is almost not fair to call them wood.
Robin Corell
Oak is fine, in fact preferred
Bill Tindal, E.TN
>I have seen mountains of wood on sticks in this area and oak is a preferred material because it is strong so that the sticks hold up over time and they don't sag. The minimum wage labor that disassembles stacks of lumber is not gentle on the sticks. What is most important is that what ever is used must be dry. It is very risky to use edging from sawing the logs. Any commercial kiln I have visited frets over dry sticks. I have dried many thousand feet of various woods and never had stain when using dry sticks, from either tannin or mold. In the summer get the lumber on sticks pronto or the sapwood will mold.
Cherry dries easily and quickly, but boards with sap and heartwood will cup because the sap wood shrinks more than the heart wood.
If you want cheap, easy and durable....
Scott in Eastern Iowa
>......go to your favorite colored borg or lumberyard and pic up a stack of 1x2 8 foot long furring strips. Menards sells them in a 20 pack all banded up and ready to go I think. Cut them in half or thirds and your done. Ive not had any problems with sticker stain on any of the woods Ive dried.
I've found that maybe 10% will warp slightly, but not enough to warrant not using them. Just add them to the bottom of the stack and the weight of the stacks above will compress it sufficiently so it wont matter.
Don't buy bargain 1x4,6,8,10's etc and start ripping them.....more than half will twist and curl...its just not worth it....plus all the time to cut and kerf sawdust wasted to boot.
Re: If you want cheap, easy and durable....
Stephen Kirk in Quakertown, PA
>I did this with good results also. Cheap and fast. Bandsaw or tablesaw makes short work of them.
Sonny Asburry
>Barry, I, like you ripped 50 pieces of dry pine boards for stickers the first time I had two poplar trees band sawed and it took a long time to do it.
When I had 22 maple and pine logs sawed (a lot of stickers needed), I just let the sawyer put the boards on the mill and he could saw 36 boards into stickers at one time. It sure saved me a lot of work and they were all consistent in thickness.
Sonny in Martinsville, Va.
