Copper plumbing question OT
Dustmaker Mike
>The house I bought has copper plumbing in it. I noticed that the builder used lengths of copper to support the water lines runs between the joyce and soldered them to it. Picture a piece of pipe between two joyce and jammed into the wood while the water pipe runs across the top if it. I have never see this done like this before so I am not sure about it. Should I be worried or change it to plastic? Thanks
Re: Copper plumbing question OT
Nat Robison
>I've never heard of it either. I always thought that (at least the hot pipe) could expand and contract a bit with temp. changes so soldering to a hanger might not allow the movement. Plus, pipes move a bit after a hard shutoff, like with a clothes washer.
As long as the pipes deliver water like they're supposed to, I probably wouldn't worry about it. It may not be standard but if the system is working, I'd leave it. You might find that freeing your pipes from their soldered hangers is a big chore for negligible payoff.
Dale Stansbery
>I had a house built in the 1970 that had the pipes to the bath tub valve supported that way. It didn't seem to be any problem.
Rick L
Re: Joist, not Joyce!
Rick L
>You could check with your local plumbing inspector.
Ernie Miller
>I wouldn't worry about it either but with copper prices the way they are you might want to support them with wood and sell the extra copper.
Larry Clinton At Frankfort (Central)., Indiana
>Mike, I wouldn't worry about it - the only problem it could cause is "noise" if the pipe is too rigid in a long run. If the pipe doesn't have any place to move when it expands / contracts from temperature change it could result in some popping etc. If that does happen, it would be easy to correct. Just cut off part of the "support" pipes with a tubing cutter and install hanging wire to support the actual plumbing. I wouldn't even remove the portion that is soldered to the plumbing.
IMHO copper is the "Cadillac" of plumbing material. I would never suggest replacing copper pipe with plastic. The copper pipe should last the life of the house. Replacing it with plastic would be like replacing redwood siding on a new house with vinyl.
>I agree with Larry. I would not bother to do anything unless I had a distinct problem. If you can actually see a pipe trying to move or squirming, I might cut the hanger pipe and install a piece of wood or a wire hanger or plastic hangers.
Also, I agree that copper is superior to plastic unless your water chemistry is such that it damages copper. (Possible on well water, very unlikely on any public water). If your water tastes like copper or you have blue green stains in sinks under dripping faucets, then I would consider plastic. Otherwise, you got the good stuff. Copper pipe often lasts 60 years on city water. I doubt alstic will do that well.
Chicago Bob
>Mike,
In the Chicago Land area, this is a common plumbing practice and meets code. I have it in my house built about 5 years ago and do not have any issues with including noise.
Bob
Not seen or heard of that one.....
Scott in Eastern Iowa
>....while it may "pass code" in some areas....it more or less sounds like a hacker was present.
Not saying it wouldnt work, but "why" is my question.
Re: Not seen or heard of that one.....
>Does sound like a "local practice". The part I don't like is that they soldered the pipes to the hangers. if the pipes just laid on the support pipe and were free to expand and contract, it would seem better to me. I suppose the pipes could wear through each other, but I doubt it. Most hangers are designed to let the pips slide without wearing through them. I have heard that leaving the flux on the pipes will eventually eat through them, but I have never seen a case where that happened.
Locally the plumbers often get scrap cable from the electricians and use short lengths of electric cable as hanger straps. I bet that started because the scraps used to be "free".
