Walnut & Cherry Coffee Table
HC Sakman
>Hi guys,
Now, these look really simple, but sizes and solid walnut tops made them challenging to built. Cherry parts are 3/32" thick shopsawn veneer as well as some 1/8" cherry veneer I've got from A&M. Clients really wanted to see dovetails, so they've got fake ones as it'd be guaranteed self-destructing to make real ones, unless the feet were solid. Top is joined with splines and countertop bolts.
I'd mention that those tapered "legs" are 3-5/8" thick at the thickest part (top). When you look at the top, cherry legs' tops are end grain, joint lines matching the outside veneer, looking like solid as the little bevel totally disguising the 1/8" veneer, which is also cut from the same 12/4 cherry that I cut those end grain
pieces. Felder would have been great if I had it! ;-)
End table: H:26" W:26" D:24"
Coffee Table : H:20" W:60" D:40"
Chico...
