OT: underlayment for linoleum
Ted Wong
>I'm laying 1/4" underlayment for linoleum flooring. The underlayment will be going on top of 3/4" tongue and groove plywood subfloor. Which direction should the underlayment run? Parallel with the direction of the subfloor or perpendicular with it or it doesn't matter. thanks in advance for advice.
Re: OT: underlayment for linoleum
Ray Thompson - Middletown,IN
>Go get some 5x5 1/4 Baltic Birch, yeah it's more expensive but will work better. Stagger the seams from the sub floor and use about 5 times more nails than you think are necessary. Then fill the seams and sand smooth. Also check all nails and make sure they are all flush with the surface, if below, fill and sand. I get my 1/4" from my local flooring store, they know I'm a weirdo woodworker so they don't ask questions about what I need it for.
Ray
Dan Donaldson
>Probably doesn't matter a whole lot, but you need to be sure that none of the seams line up.
wes bischel
>Yep, use good quality materials (no luan!) and make sure you follow the nail/staple schedule - 4"oc I think it is. Some underlayment has the locations printed on the face. Also, a quick way to make sure all the staples are set is to use a framing square - push it along the floor - if you hear a metallic "click", a fastener is sitting proud.
Oh, knee pads are a good idea. ;-)
Good luck,
Wes
Kneale Brownson in Northern MI
>Use flooring underlayment grade solid core ply. I always pay a bit extra and buy it from my flooring supplier. I also use an air gun and staples to anchor it. Lot less likely to have staples pop loose than nails. Make sure they all go down flat, though. As others note, stagger seams and fill any gaps.
