Unisaw top is cracked !!!
wudwork
>Around 4" long. Bought saw new xmas 04, warranty is 2 years. New top is $500 + delivery. Sent email to Delta, no response. Anyone know how to stop further spread ? Facing saw it is between right miter slot and right far corner of saw. Crack runs parallel to miter slot starting at very back end of saw.
How does one handle this ??? Thanx, Tom
Re: Unisaw top is cracked !!!
Ben
>We stop drill cracks in aircraft all the time. A little stress relief at the end of the crack usually stops it for a while. Trick is finding the end of the crack, usually use an eddy current inspection. The crack can extend a lot further than you think. Find the end of the crack and drill a small hole all the way through the material, a bit tricky for thick material. Ideally the crack propagates to the hole and does not carry through it.
Best of luck.
Ben
Fix it with butterfly keys :-)
HC Sakman
Ken Oakley-Sunny St. Cloud, Fla.
>Whenever I have a need for anything from Delta, I call them on the phone and have never once been disappointed in their response. In fact I have been amazed at the above and beyond effort they have made to make me a Happy Camper.
Ray - SW Ohio
>Call them, emails are easily missed.
>I agree with the guys saying to call them. I cut a hole in the door of my bandsaw for a dust pickup. (It went against my grain to cut up my saw, but I saw it as a bold move toward superior dust collection.) Then I found out Delta offers a four inch dust pickup port for the saw that goes on in place of the little tinky one that comes with the saw. I called them and complained that I was angry about cutting up the saw. That they should have included a flyer or offer with the saw for the dust port. Without hesitation, they sent me a new door of the saw. (Actually two, because they sent the wrong one first) I really did not expect them to do that. I CUT THE SAW. I just wanted them to make the dust port better known for everyone else.
I would call and explain that you did not abuse the saw and you believe it came from the fact they have moved production off shore (If so) or that they rushed the milling of the top and made it out of Green cast iron to cut costs and see if they don�t make you an offer.
Ed ONeill
>If this is a non abuse situation I would get on the phone to Delta. I wouldnt be suprised if a new top would be on your doorstep in a few days. This is definitley a defective part situation that Delta should take care of in order to keep their reputation for solid tools intact. I'll be looking forward to hearing what they have to say.
Jennifer@Indy.USA
>That sounds like a serious issue. Not common. I would think Delta would want to get their hands on it just to investigate!
I'd be furious!
Jen :(
yuchol
>That is awful, sorry to hear that.
One way many people stop the streading of crack is to find the ends of the crack and drill a hold at each end. IF you wanted to know exactly where the crack began and ended, you can always take it to a local engine builder (some Action Autor stores have them o nsite) and have them magnaflux it, that's how the pros find cracks in engine blocks. But I would start with a call to Delta first.
Re: Unisaw top is cracked !!! UPDATE
wudwork
>Called Delta, very nice folks advised I had to remove top and take it to authorized repair center. The closest is about 40 miles away and only open M-F 7-5. It is located a few miles from MLCS woodworking store in Phila. PA. I called center and spoke with a very nice manager. He explained simple process of removing my top and bringing it to him. He promised I would be happy with outcome. Now I need to schedule day off work, remove beis fence, remove 52" side table and unbolt top THEN xfer the 40 lb beast to truck and take to him.
Update to follow after visit. Tom
wudwork
>Here is a picture of crack with can of Teak Oil for size reference. Its possible there is another adjacent crack? Anyway, I plan to see Delta factory auth center manager in next few weeks for resolution. Tom
Eddie Pacheco, San Jose, Ca.
>To me, from the photo, it looks like a deep scratch. Just seems a little too straight to be a crack. Are you able to see the crack from the bottom of the table?
Yeah, I agree...........
Basil
>....or I'm not seeing the crack.
I believe I'd build a dam around the "crack" with some caulk, putty, maybe even some modeling clay. Then carefully add a shallow layer of some WD-40 or other penetrating oil to the 'lake' and see if it penetrated thru to the bottom side.
Interesting....
>When I looked at the picture I was expecting to see a jagged crooked crack. (I am a Home Inspector; perhaps I have inspected too much concrete?) I was trying to figure out why it would crack in a nice straight line and stopped so distinctly. I would have thought it would be crooked and tapered and fade out to an invisible crack. I agree with the others, it looks more like a scratch. Some Home Inspectors use WD 40 for finding cracks in heat exchangers. It will go through cracks that will resist water. Give it a try. Let us know.
Re: Interesting....
Chuck Lenz
>I see 3 lines all parralell to eachother. Looks like a old saw too. Maybe it's along one of the cast ribs undernieth or it's a deep scratch. Tough call without being there.
