piano
ponglee
>The wood on my piano is sun damaged. Is it possible to sand the raised grain and refinished the piano without affecting the piano performance?
piano
ponglee
Re: piano
Paul Woolson
>I assume you are talking about the outer case of the piano. Yes, you can refinish that. My only hesitation would be when you say raise the grain. That usually involves water, yes? I'd avoid that step. Just sand to 320 and refinish.
The Whole Piano, or just a portion???
>Good Afternoon Ponglee,
Is it the whole piano or just a portion? And what wood and finish are used in the construction, and are the pores filled? Pianos are a big project and must be done right. Perhaps you only have to finish a portion. If so, great! But be sure you practise on many scraps to be sure you get the correct color, shade, texture, and sheen to match the rest of it. If your refinishing skills are shy of professional, I suggest you get professional help.
George
Re: piano
DB
>If you do sand, sand lightly. The piano is most likely made with veneers.
Re: piano
paul in AZ
>The outer case is largely incidental to musical quality so whatever you do to it will not meaningfully affect the piano's sound.
The functional musical guts of a piano are a heavy steel internal frame that resists the immense torque of string tension; and the soundboard.
Re: piano
Paul Dwight
>I would be scared to try to refinish an entire piano without completely disassembling the case. I'd worry about sanding dust and finish making their way into the keyboard and affecting the action. I wouldn't do it.
And incidentally, disassembling a piano's case is not a DIY job.
There are portions of the case that come off quite easily, though. If you can take off the sun damaged portions and work on them separately, I don't see any reason why you couldn't do the work yourself. You'd have to match the new finish to the old work, which might be very difficult. A high gloss, filled-pore piano finish is not easy to replicate.
Good luck! -- Paul
