A55 Smoothing Plane
OT. I probably need someone to hold my hand.
Don Henthorn
>I have a new 160 gig WD caviar SE IDE disk which I want to install as my boot drive. I presently have an 80 gig Caviar drive as the boot drive, which is named J by the way. Don't ask me, ask Windows. I was also thinking of just taking the present drive out and saving it as back up in case I had problems later on. Would this work?
Anyway I have downloaded and burned a live disk for Ubuntu and would like to be able to dual boot either WinXP or Ubuntu as I choose. I am unsure as to how to go about this. I know how to set the jumpers on the two drives to make one the master and the other the slave. I was thinking of installing the two operating systems on the new drive and then installing most of my programs on the drive and then just dragging and dropping the data files as I needed them.
Is it easy to get Ubuntu to read files from the WINxp part of the disk?
My first questions are which do I install first?
What do I have to do as far as partitioning to get this done.
Will I run into problems dragging data from a disk named J to a disk named C?
I am so full of questions I am ready to burst.
It's terrible to have just enough knowledge to be dangerous. Maybe someone knows of a site with explicit instructions for a complete idiot.
Re: OT. I probably need someone to hold my hand.
Dan Donaldson
>I just went through this. In my case, I dumped windows completely and am just running Ubuntu. I finally have everything running the way that I want pretty much, so am going to leave it alone for awhile.
First, if you can, it is not a bad idea to remove the current boot drive and keep it in case of a problem. You can just put it back in and reboot and be right back where you started.
If you can, it is better to install Ubuntu and windows on separate drives, and have two partitions for ubuntu. That way, you don't have to mess with the partitions during the install. It is not really difficult, but most of the problems that people seem to have with installs are with partitions.
Install Windows first and get it running, then install ubuntu. The ubuntu setup will detect the windows install and set it up for dual boot. Do NOT try to install ubuntu on the same drive as windows and let it move the partitions. You may lose the Windows install. If you want it on the same drive, set up the partition before you install ubuntu and then just let it take over the one you set up for it. It is also best to put your home directory (sorta like My Documents on steroids) on a separate partition because that way, you can upgrade, reinstall etc. the ubuntu without losing any data. You home directory will stay and be reused if it is on a separate partition.
For help, the forum on the ubuntu website is great and the people there are very helpful to those of us that don't know much. It is a pretty steep learning curve, but a lot of fun.
I assume that you downloaded and burned the iso image for ubuntu. I would also suggest that you run it as a live cd before you install so that you can make sure it recognizes your hardware.
The main issues that I had were:
Getting all of my mouse buttons to work.
Getting it set up to read and write to NTSF partitions
Getting the screen resolution where I wanted it.
Getting wine configured to run a couple of programs that I wanted.
Probably should not take up too much bandwidth here with this unless there are more that are interested. If you need any help (and believe it, I am a total novice in this realm), feel free to ping me offline, or if it would be easier to talk, let me know and I will send you a phone number.
In my case, the more I see of Vista, the less I want it. I figure that MS is getting enough resistance to Vista, that they will stop supporting XP sooner than some of the others just to make people upgrade. I still have one box running XP, and I am hoping that by the time they quit supporting it, I will know enough about Linux that I won't care. The Linux box is my main computer and I have no plans to ever put windows on it again. </rant >
So far, I really like it. Fast, relatively easy to set up, and does almost everything that I need. Wine takes care of the rest ;-)
Thanks, Dan
Don Henthorn
>I guess I need to spend more time with the live disk and visit the UBUNTU forums although I haven't been able to get much from them do far. Guess I don't know how to use them.
I, too, would just like to get rid of Windows but am not sure if there is something I would miss by taking it off my computer.
I have a 20 gig Maxtor drive that would probably hold everything I need to save from the present hard drive. I may just get Acronis and try to ghost the boot drive to the 20 gig drive and then save that as an emergency drive. That way I could use the two remaining drives for Ubuntu and Winxp and then see if I can get Ubuntu to do everything I need it to and then get rid of Winxp.
Again thanks for the info. I'll not take up any more bandwidth on this problem.
Pat Evans
>Dan, you've probably seen this, but it is funny:
You have to be old enough to remember Abbott and Costello, and too old to REALLY understand computers, to fully appreciate this. For those of us who sometimes get flustered by our computers, please read on...
If Bud Abbott and Lou Costello were alive today, their infamous sketch, "Who's on First?" might have turned out something like this:
COSTELLO CALLS TO BUY A COMPUTER FROM ABBOTT
ABBOTT: Super Duper computer store. Can I help you?
COSTELLO: Thanks. I'm setting up an office in my den and I'm thinking about buying a computer.
ABBOTT: Mac?
COSTELLO: No, the name's Lou.
ABBOTT: Your computer?
COSTELLO: I don't own a computer. I want to buy one.
ABBOTT: Mac?
COSTELLO: I told you, my name's Lou.
ABBOTT: What about Windows?
COSTELLO: Why? Will it get stuffy in here?
ABBOTT: Do you want a computer with Windows?
COSTELLO: I don't know. What will I see when I look at the windows?
ABBOTT: Wallpaper.
COSTELLO: Never mind the windows. I need a computer and software.
ABBOTT: Software for Windows?
COSTELLO: No. On the computer! I need something I can use to write proposals, track expenses and run my business. What do you have?
ABBOTT: Office.
COSTELLO: Yeah, for my office. Can you recommend anything?
ABBOTT: I just did.
COSTELLO: You just did what?
ABBOTT: Recommend something.
COSTELLO: You recommended something?
ABBOTT: Yes.
COSTELLO: For my office?
ABBOTT: Yes.
COST ELLO: OK, what did you recommend for my office?
ABBOTT: Office.
COSTELLO: Yes, for my office!
ABBOTT: I recommend Office with Windows.
COSTELLO: I already have an office with windows! OK, let's just say I'm sitting at my computer and I want to type a proposal. What do I need?
ABBOTT: Word.
COSTELLO: What word?
ABBOTT: Word in Office.
COSTELLO: The only word in office is office.
ABBOTT: The Word in Office for Windows.
COSTELLO: Which word in office for windows?
ABBOTT: The Word you get when you click the blue "W" .
COSTELLO: I'm going to click your blue "w" if you don't start with some straight answers. What about financial bookkeeping? You have anything I can track my money with?
ABBOT T: Money.
COSTELLO: That's right. What do you have?
ABBOTT: Money.
COSTELLO: I need money to track my money?
ABBOTT: It comes bundled with your computer.
COSTELLO: What's bundled with my computer?
ABBOTT: Money.
COSTELLO: Money comes with my computer?
ABBOTT: Yes. No extra charge.
COSTELLO: I get a bundle of money with my computer? How much?
ABBOTT: One copy.
COSTELLO: Isn't it illegal to copy money?
ABBOTT: Microsoft gave us a license to copy Money.
COSTELLO: They can give you a license to copy money?
ABBOTT: Why not? THEY OWN IT!
(A few days later)
COSTELLO: How do I turn my computer off?
ABBOTT: Click on "START".............
Ubuntu install
Chuck W
>I just installed Ubuntu on one of my xp machines and I did install it to the same drive. I created a separate partition on the drive and every went smoothly. I may try it now on my main machine as my older computer is the one I try things on first.
Re: Ubuntu install
Dan Donaldson
>Did you create the partition with the live disk? I have seen threads where the Windows install gets trashed if you let gparted do the new partition. Not always, but if Windows were important to me, I would not take the chance without a full backup. Of course, I do tend to be a bit paranoid ;-) I didn't care because I got rid of windows. I have two 250 gig drives, each partitioned in half. I have ubuntu installed on one partition, my home on the second one on that drive, one of the second drive partitions is used for backups, and the other is ntfs just cause I was too lazy to change it and I can read and write to it.
Re: OT. I probably need someone to hold my hand. *LINK*
Jerry Nicholson
>Check the link for the LINUX UBUNTU forums. To ask questions you will have to sign up as a member - no cost so no sweat. The forums have a lot of members and there will be someone that has done everything you want to do. You won't find those folks as polite as the folks here on Wood Central and you will find some of them to be downright arrogant. They are likely to tell you to do things without any explanation as to why you are doing them or what the commands mean and if you want to get serious you are going to need some books. I found a lot of LINUX books at the bookstore, some of them specifically for UBUNTU. I installed UBUNTU on one computer to see if is really "ready for prime time" and could be beneficially used by some of the elderly folks that I help with computer problems (elderly is anyone older than me). The answer is NO WAY, not yet anyway. Windows XP is far easier for a non-geek to comprehend and deal with. Many LINUX fans (particularly those in the LINUX forums) get really defensive when you mention something like this to them. I can deal with it because I have been doing computer stuff for a LONG time although I may be 50 years too old to be a proper geek:) I do not plan to abandon Windows in the near term although I have no intention of ever converting to VISTA.
Jerry
UBUNTU Forums
wilbur
>I've not set up a dual Ubuntu/Windows system, but I have done a dual Gentoo/Windows system before.
As mentioned before, the best source for information is probably the Ubuntu forums, but if you Google for "ubuntu dual boot" there's a lot of information out there, including a video(!) guide.
Ubuntu Windows dual boot video
I messed with an Ubuntu offshoot
Curt Harms
>called Mepis, which is reputed to have pretty good hardware support. I partitioned a 60 gb. IBM notebook with BootItNG. I have a W2K FAT32 partition, a FAT32 data partition, NTFS partition, Mepis partition, and some unallocated space. With BootItNG I can have more than 4 primary partitions but I have to let BootItNG manage the partitions, otherwise I'd have to get the partition count down to 4. Mepis installed and recognized most stuff including the built-in wireless adapter. The trackpoint device worked and well as left and right buttons but the scroll button didn't. The touch pad worked with minimal configuration.
I haven't spent a lot of time with this but could surf the net fine. One problem I did see-I downloaded Adobe Acrobat Reader for Linux. It wouldn't install because of missing files. I can see what people talk about when they mention "dependency hell". I haven't tried to set up a printer yet. Mepis didn't seem to recognize a Linksys PCMCIA wireless network adapter. Still, for a desktop machine with wired ethernet, Mepis seems pretty easy.
Curt
Dan Donaldson
>I agree about the ubuntu forums. I got most of what I needed just from searching the forums, a couple more by asking. So far, I haven't run into any of the arrogant ones, everyone has been very helpful.
As to ready for prime time, it probably is not, unless you are willing to learn some command line stuff and have at least a fair understanding of the internal structure of a computer. (software/os). That said, most of the issues involve the installation and setup. For someone that was just going to be surfing the web, doing a bit of e-mail, and possibly writing a few docs that won't have much funny formatting, it would be basically transparant that it is Linux. The best thing for that type of user is that once someone sets it up for them, they should have no virus or trojan issues and if they don't know the sudo , they would not be able to damage the system. In reality, if I had to set up and maintain a computer for the type I described, I would rather do it with Linux. With just a few minutes of training, they would not even realize that it was not Windows, especially if you install the KDE desktop instead of Gnome. If they had to install and configure it, then I totally agree that it is not for the faint of heart. There is a fairly steep learning curve. (at least for me, since I have been on Windows from version 1.0. (1.0, windows 286, 386, 3.0 3.1, 3.11 for workgroups, 95, 98, xp, and ce for automotive in a development environment). I have done a fair amount of embedded systems programming over the years, so that helps. Anyone scared of the command line would be in trouble real fast.
I am starting now, because I want to be familiar with Linux before Vista becomes mandatory. Ain't going there ;-)
Agree in part...
John in New Mexico
>Once set up, regular use requires no particular skills. My parents are a perfect example, XP keeps croaking on them, and they use the linux partition I installed as a backup. If only mom wasn't hooked on spider solitaire, I could probably ween them off windows entirely! (None of the linux spider games I've set up for her seem to be the same as what she's used to).
But I disagree that its not ready for prime time. If it came pre-installed on the computer, it would run with fewer problems than windows, and the average user wouldn't have a useless computer in a couple years from lack of maintenance and virus scanning - and I've found most casual users don't do this stuff, or don't do it thoroughly. The ease of use argument for windows doesn't hold water, as few users install and cofigure it themselves. Not to get defensive on ya! ;)
John
Re: Ubuntu install
Chuck W
>Dan,
I created the partition before hand using Partition magic and then installed Ubuntu to it.
Re: Agree in part...
Dan Donaldson
>I think that is kinda what I said ;-) IF it is preinstalled, or someone sets it up for you, It is totally ready. Setting it up cold on a machine that has a random group of components is not quite there yet. In general, you can build a machine from parts, get a Windows CD, do the install, and it will probably work as most of the hardware setups have already been figured out. With Linux, that is not necessarily the case, although it is getting much closer. I think within a couple of years it will be there. There is still a lot of hardware out there without stable linux drivers, and it is taking time to get the vendors to write them, or someone willing to reverse engineer them. It is the hardware drivers that I think are holding it back now, not the OS itself.
I mentioned that for someone that I was setting up and maintaining a machine for general purpose use, I would much rather give them a linux box. Unless they understand su (or sudo), it is unlikely that they could do much damage to the OS.
Jerry Nicholson
>I don't think I can quite agree on the virus and trojan issues - if people build it, other people can break it. I might be paranoid but over the many years I have been messing with computing machines, I have determined that paranoia may be a virtue. That is why I use ZoneAlarm on my Windows machines in addition to the firewall in the router. I am about to install Firestarter in the Linux computer. Ubuntu's distribution includes a lot of very useable software including OpenOffice and Firefox. The Evolution e-mail program also seems to be fairly easy to set up and use.
Jerry
Curly Smith
>Do you have a copy of Western Digital's Data LifeGuard Tools? If not, go to their website and download it (www.wdc.com), it will create the partitions you need for your new hard disk and will copy data from the old drive to the new FAT32 partition.
If you make a drive-to-drive copy the programs will not work unless your new FAT32 Windows partition is also the J: drive. You can specify (or force) drive names when you create and format the partitions.
You'll need at least 1 FAT32 partition for Windows, you'll need 2 EXT3 partitions for Linux (1 large one for the operating system, 1 small one for the swap file), any other partitions are up to you.
You can either create the partitions from the Linux install disk or you can create them beforehand. You'll also need a dual boot utility - one is included with Linux (it's called GRUB).
I'd create the necessary partitions first using WD's utility (again specify that the FAT32 partition, with NTFS is the J: drive) and I'd make the FAT32 partition the boot partition. I'd then copy the old hard drive to the FAT32 partition (using the drive copy utility supplied by WD) and then remove the old hard drive (or just unplug the cables) for safekeeping.
Once I had Windows up and running (it should work fine but there might be a few programs that need help) I'd install Linux. The Linux installer should recognize the FAT32 partition(s) and should allow you to install Linux in the EXT3 partitions that you created earlier (or allow you to create the necessary Linux partitions if it doesn't like what you previously created and then install). It should also install the GRUB utility that will ask you to boot Windows or Linux.
By installing Windows first and disconnecting the old HD you don't really have any risk. If the worst case scenario happens simply disconnect the new hard drive, reconnect the old, get on the internet to do some research and start over.
You're right...
John in New Mexico
>I was thinking more of Jerry's post than yours! Sorry bout that.
John
Dan Donaldson
>Agree. I guess I will say "for the moment" ;-) I am sure that when linux becomes more popular, it will be seen as more of a challenge for hackers, and I am sure that someone will find a way. That said, it is inherently more secure than most Windows installations. I do have the firewall in my router, and run port scans etc. periodically to make sure something that should not be open has not gotten compromised. A lot of Windows installations could help themselves a lot just by not running as admin all of the time, If I were to take the chance (as a lot of users seem to do ;-( I would rather run a linux box without virus and firewall software than a Windows box ;-)
That's funny.......
>I like that. How about adding this:
How do I get the photos from my camera?
Did you download them to your computer?
I think so.
You have to look in My Pictures.
I don't want to look at your pictures I want to see my pictures.
No, you have to look in the folder My Pictures.
I said I don't want your pictures I want my pictures.
No, you have to look in your folder called My Pictures.
Okay, where can I find the folder called My Pictures?
In My Documents.
Why are My Pictures in your documents?
No, you have a folder on your computer called My Documents.
Okay, where can I find this My Documents folder?
Click on My Computer.
Your computer?????
Happy Woodworking!
Other extreme.... MAC
>I'm not knocking Linux at all. I've been using UNIX and Linux for decades ....... oooo, I'm getting old :(
But seeing your comments made me chuckle:
"...the main issues I had were: Getting all of my mouse buttons to work....Getting it set up to read and write to NTSF partitions
Getting the screen resolution where I wanted it....."
I have to lsiten to my B-I-L priase the MAC all the time. Software? You need to LOAD software on a Windows PC? It doesn't do that automatically? Configure? What? What's configuring?
People spend more to get a MAC because there's relatively nothing to do to make it work. People pay less and get Windows PCs and have to struggle a bit more. But Linux still is for the geeks of us who are willing to work at getting mouse buttons to work.
Makes me smile.
Happy Woodworking!
Re: Other extreme.... MAC
Dan Donaldson
>But it is fun ;-) As you said, for the geeks of us. Besides, it is a lot easier to get dangerous and break the linux install than a MAC. I wouldn't get the challange of fixing whatever it was that I broke playing around. (What do you mean the x-system won't start? I only made one type editing the xorg file.) ;-)
I also have nothing against MACs, but it is a lot cheaper to play with linux. (did I mention that I need to get a life?) ;-)
You mean, 'typo'? ;^)
Jason Roehl in Mulberry, IN
Dan Donaldson
>See, that is what happens ;-)
Jerry Nicholson
>You might also want to have a look at Linspire. It's claim to fame is a much easier transition to Linux for Windows users. It does cost money but not a lot. I haven't tried it but I think I will after I get a good removeable hard drive rack for my secondary computer. I understand it was formerly known as Lindows but "guess who" sued over that one. I don't know if you can dual boot with Linspire but when I dug into their website I find that the current release is based on Debian Linux and the next release will be based on Ubuntu, which in turn is based on Debian. There is also a free version named Freespire but you are right back to GeekLand on that. Freespire also appears to be way behind the latest release of Ubuntu. I read someplace that the Linux true believers don't like Linspire because from a user standpoint it looks and works like Windows and a lot of the Linux folks really hate Windows and Microsquish.
Jerry
http://linspire.com/
Curley, Is there a reason for using the
Don Henthorn
>FAT32 file system instead of nfts for the Winx partition?
Re: Curley, Is there a reason for using the
Dan Donaldson
>Both Windows and linux can read/write FAT32. However, ubuntu can read ntfs and it isn't hard to get it to read/write. I would not use fat32 for anything. There is also something that you can run in Windows to enable it to read ext3. Up until fairly recently, fat32 was the only alternative if you wanted a partition readable by both, but that is no longer true.
