Router glue joint bit adjustment
Tom850i
>I recently saw a step by step instruction guide for adjusting a glue joint bit so that you can get perfect alignment. Does anyone know where I can find instructions?
Re: Router glue joint bit adjustment
Rick L
Re: Why use one?
Rick L
>That bit is the biggest waste of time and money. A good butt joint is all you need. I've been working with with wood for over 30 years in factories and custom shops. No uses this bit except the hobbyists.
Carol - Strawberry, AZ
>Specific instructions may depend on the brand bit you have. But.
Generally, they are keyed to the center of the cut profile. So in general terms, match the center of the bit profile to the center of the thickness of the stock you are routing. The height adjustment of the bit is totally dependent on the thickness of the wood. So if you save scraps for the next time you want to use the bit, understand that the sample pieces are only good if the wood is the same thickness.
Kinda fussy bits.
Why bother?
Bill Tindal, E.TN
>This joint adds no value to edge gluing.
del schisler
>Infeed is 1/16" narrower to joint the edges of your wood with a flush trim bit Here is a good site to visit http://us.oak-park.com/catalogue.html?list=TF01--&product=F020
Tom850i
>Thanks. These web sites are exactly what I was looking for. I already have the bit, and the fine height adjustment is what I was seeking.
Chad Pearson
>The other bad thing about the glue joint bit is that it looks awful (in my opinion) where the end grain of the joint will show. It even looks worse when that end grain is routed with some type of profile bit.
