A bit OT...Countertop installation?
Stuart Hough
>I am doing my first install on a set of base cabinets and have no clue as to a way to attach the countertop. What is the best/easiest way to do this? All ideas are welcomed!
Re: A bit OT...Countertop installation?
Re: Installing countertop
Al Stokka - Cambridge, Iowa
>Stuart,
Posted the questions three times so you must really, really want an answer. ;^) Seriously, if you refresh, or reload, the main page, your first post would have appeared.
As for attaching the coutertop, I've seen three methods:
1. Drive screws up through corner braces which are attached to two adjacent sides of the cabinet. Be sure the screws are the proper length so they don't come through the countertop.
2. Drive screws up through a cross bracing (front to back). Same warning about screw length as item one.
3. Construction adhesive applied between the countertop and the cabinet.
I prefer method one or two.
Al
Stuart Hough
>Thanx! and sorry for the multiple posts...sometimes my 'puter acts real ornery when I try to post to this message board, and I have been told (though I'm not sure I believe them) that I am a bit impatient.
wood vaneer on MDF
Wayne Carson
>some installers use hot melt glue sticks spaced about 12" apart.
Wayne Carson
>some use hot melt glue gun. Some times my program puts the wrong subject.
