OT - Metal Frame Pools
John in MD
>Thanks in advance for any replies, and apologies for the OT posting...
The kids have outgrown the plastic wading pools, and our current financial state don't allow the purchase of a real above-ground pool. We've heard some scary things about the soft-sided, bulbous-looking "easy-set" pools, but the same company makes similar pools with straight sides, held up by metal pole framework.
We're wondering if anyone has personal experience with these sorts of pools. They look like an OK deal (keeping in mind they're sort of a bridge between the plastic wading pool and a "real" pool). Sizes should be good for the kids at their ages, and rough-housing isn't an issue, so durability really would relate to how many years of use we could expect to get from one of these things.
Also, any tips or tricks about installation - seems straightforward, but I wonder how flat an area it needs to be on (How flat is flat??), and ideas for surface prep (dig out turf grass? lay groundcloth and cover with sand? lay sheets of fiberglass insulation material for a flat bed?). The instructions are pretty vague on this, and sounds like you just spread the liner over your existing lawn, build the frame, and fill it with water...
Maintenance issues? Overwinter storage hints??
Any replies will be appreciated - either on the board or direct to my email.
Many thanks.
-John-
