Titebond Glue
alex
>Hi,
I would like to know if the Titebond wood glue III is better than Titebond II or I.
Thank you.
Alex
Titebond Glue
alex
>Hi,
Thank you.
Alex
Re: Titebond Glue
Larry Clinton At Frankfort (Central)., Indiana
>I use titebond 3 for many projects, including cabinets (also use LV cabinet glue) and outdoor stuff. It has a longer open time and is "waterproof". It is just slightly stronger than the Titebond 1 & 2 - all are stronger than the wood when properly applied to a good joint. Specs from the manufacturer are listed in the link below. I use Hot hide glue or Titebond liquid hide glue for most furniture.
http://www.titebond.com/WNTitebondIIITB.asp
Re: Titebond Glue
>Depends on your definition of better. It is more waterproof than l or ll. I tried it but felt like it was runnier than the titebond ll that I was used to so I went back. I will use it for certain projects, it's good glue I just don't like it as well as the ll.
Re: Titebond Glue
Larry Marker in Alabama
>I like it because of the longer open time. I also like the LV cabinet glue -- perfer it in fact, but if I need to get some quick, I'll buy the Titebond III.
Re: Titebond Glue
Howard Acheson
>There are three claimed advantages.
o It has a longer open time. But, white PVA or Titebond Extend both are equal in open time and a lot cheaper.
o It can be used at 47 degrees where the lower limit of other PVA's is 55 degrees.
o It is waterproof while Titebond II is water resistant. Waterproof means it can be used in a totally submerged application. Now an application that is applicable to most woodworkers.
Given it's much higher price, I would go with standard PVA for interior woodworking and Type II PVA for exterior use.
Re: Titebond Glue
JRutter
>The TB3 seems to dry a little more flexible than the TB2. Maybe that is part of the reason why it can hold upbetter to wet (expanded) wood than TB2. I like the fast tack of the TB and TB2, so I use them for most things (about a gallon per month). TB3 is nice for more complicated glue-ups or where there is more possibility for movement along a glue joint...
Better by what measure?
Bill Tindal, E.TN
>Furniture factories use the equivalent of Titebond original. That information alone should be sufficient to decide what adhesive to use for interior furniture. If you want more open time with it dilute with 5% water. The bond is stronger than wood, it has a strong initial tack, it has stood the test of time( at least for 40 years), it sands reasonably well, and it is cheap, and it has a shelf live of years unlike the crosslinking varients that begin to thicken in the container after a year or less. What more could one ask for for furniture assembly?
For certain specialized applications the others may be better.
Re: Better by what measure?
alex
>Hi,
I just wanted to laminated six boards of Purpleheart or Jatoba for a kung fu wooden dummy. That is why I asked if TB1 or TB2 is better.
Thank you.
A. Blais
Re: Titebond Glue
Jim Dillon
>Alex,
After using Titebond-III as long as it has been out, this season, I'm going back to Titebond-II for the following reason. After trying several methods of wiping off excess glue during glue-up, I started to use the method of waiting, say, 20 minutes, then gently peeling off the excess glue with a chisel. By that time, Titebond-II had cured enough to allow this and this method seemed to work well - at least for me. Well, I have not had such great luck with Titebond-III. Even if I wait 45 minuets or so, it just seems to remain kinda gooey. And if I anticipated a project where I needed a lot more working time, I'd use Titebond-Extended or LV cabinet glue. Now if I was making an outdoor project, then, for me, Titebond-III makes sense. But YMMV as they say.
Oh yes, I've used both T-II and T-III on jatoba and they both worked just fine with no pretreatment of the wood needed; I have no experience with purpleheart though. Good luck.
Jim
second hand advice
Bill Tindal, E.TN
>Someone Steve Knight, on the hand tool site uses Purple heart for wooden planes and claims gorilla glue works best for it. He has a web site and you could email him for advice.
By all means test what ever adhesive you use on oily woods. Make a lap joint. Let adhesive cure. Place in vice and bash apart. Look for wood failure. If less than mostly wood failure then choose another adhesive.
Re: Titebond Glue
>The absolute best Titebond Glue is of course Titebond's Liquid Hide Glue.
Does not suffer from creep, largely transparent to stains and finishes, no swarf, easy to clean up, even the next day. Washes out of your clothing and is reversible.
What ever glue you use, tooth or key the surfaces for better adhesion.
Stephen
Re: Titebond Glue
alex
>What do you mean by Does not suffer from creep?
Thank you
Re: Titebond Glue
>Yellow or white glue will swell up forming a ridge or shrink leaving a void in the joint. Just the nature of the stuff. It is a thicker glue joint as hide glue and liquid hide glue that shrink when they dry making for a tighter joint.
Stephen
Re: tooth or key the surfaces
Dale Lenz
>Stephen,
Respectfully, I have not heard those words since the 1950's or at least seen them written since about then. All my my reading on gluing has said a hand-planed surface gives the best gluing.
Intentional roughing
>Dale,
According to many sources intentional roughing (toothing or keying) increases the holding capacity of any glue from 5 to 30%. More surface area and something for the glue to grip too.
Stephen
My vague recollection is that its helpful with
John in New Mexico
>hide glue, but not necessary with the various pva's, poly's, or resin glues. Couldn't cite a source on this to save my life, but that's what I seem to remember reading.
John
Re: My vague recollection is that its helpful with *LINK*
Dale Lenz
>Here's one source below, but is not necessarily referring to hide glue.
Best surface for gluing
Neat link--thanks!
Jason Roehl in Mulberry, IN
