Carter Band Saw Tires
Ray Newman
>Colleagues: @ the 4/27-29/07, Puyallup WA wood show, I purchased a set of the Carter band saw guides for my 15 + year old Delta 14� BS.
I figured that if I was installing the new guides, I might as well overhaul the whole saw & get new tires (it still had the original tires) & tensions spring.
Pulled the saw apart today & no problem installing the new guides.
Problem or question that I have is w/ the tires: the old tires were 1� wide; the new Carter �Blue� (urethane) tires are 7/8� wide.
Does anyone see any problem w/ using the narrow tires, if I can center them on the rim?
Re: Carter Band Saw Tires
marc rosen
>Hey Ray, will the tire strecth fill the gap when stretched over the wheel. I replaced my tires with Iturra brand but I can not remember if they measured the same width before they went on or if stretching made them fit. I would be reluctant to use them if there was a gap between their edge and the wheel's rim.
Marc
Mike in VA
>I installed of set of the Carters on my really old Walker-Turner bandsaw. This saw also had 1" tires on it. The 7/8" Carters have worked out fine for me. The 1/16" gap on each side has not been a problem.
I got the tire centered on the wheel by setting the rule in my combination square for a 1/16" extension and ran that along the edges of the wheel, while the tire could still be moved easily, to get the edge spacing even around the wheel. If you don't do this, it will cause the blade to wander front-to-back a bit.
Re: Carter Band Saw Tires --Update
Ray Newman
>UPDATE: My 15+ yrs old Delta 14" BS still had the original tires & spring. The guides were Ituura roller guides which just never seemed work well. I purchased the Carter guides, "Blue" tires, & a spring. I also bought the upper guide that is for 1/4" & smaller blades. I thought that if I was spending the money on the guides, I might as well "rehab" the some of the major components.
As I posted earlier, I intially had some concerns 'bout the tires are they are 7/8" in width & my older OEM tires were 1". I called Carter & the tech advised me to install the tires so the edge of the tire is against the front of the rim. He said that since the great majority of the BS are made overseas & have a 7/8" tire, they make the tire to the new "standard."
Installation of the new upper & lower guides was pretty much straightforward.
After checking & re-adjust the wheels to "dead-nuts-on" coplanar & installing a Delta 1/2" blade, I adjusted the guides per the instructions. I also installed the rip fence.
My BS has the 3/4 HP motor. Took a 16" long piece of 2X4, moved the rip fence for a 1/2 cut & went @ it. NO drift! I did it again as it must have been a "fluke". Same results. & cut was 1/2" @ the start & 'bout 31/64" on the end! I have never gotten such accuracy w/ my old guides. & mind you this was NOT done w/ a premium blade.
I then shifted the fence to about 1/16" & made a series of "resaws" on the same 2X4. Results for the 6 cuts -- all were 1/16� . �Nevva� was able to do this before!
Then, I drew a 5" dia. circle on some 3/4� Melamine & cut it out w/o circle cutting jig. D*mn I was impressed w/ myself -- it was just 'bout on. & again w/ a stock Delta blade.
Next. I took some more scrap 3/4� Melamine & drew some curves. Same results.
Now I�m not the best BS operator as I have difficulty maintaining a steady feed rate & I need a great deal of light to see the line. I� think that if I would have taken the times to plug in the high intensity BS lamp & mark a cleaner/sharper line, the results would have even been better.
One thing that I do differently is after tension the blade & centering & tracking it the tires, I 1st adjust the upper inboard guide, then the lower inboard guide. Next, I do the upper outboard guide, then the lower guide. I employed a cash register receipt as a feeler guage & adjusted the rear (thrust?) bearings to �bout 2 thousandths off the blade.
Get the tension release too!
Jim Moore
>I updated my 14" JEt with all of the Carter goodies and it made a great difference for me too. I especially like the tension release. I saves undo pressure on the saw when not in use, as well as keeps the blade from stretching out over time. IT is nice to just walk up to the saw, raise the tension bar, cut wood, then release the tension. IT may be pricey, but to me it is worth every penny.
Congradualtions and a question
>Ray, How did you get the wheels coplanar? Were they coplaner without the blade. That's what I did and once the blade was on, they were no longer coplanar. How did you do it?
Re: Congradualtions and a question
Ray Newman
>W/o the blade, the top wheel was way off! & it took a great deal of adjustment to track properly.
I placed an additional (hardware store) washer behind the top wheel. I took the upper wheel part to the hardware & found the appropriate sized washer. I also bought 2-3 spring clips since they were a great deal thinner. As it turned out, I only needed the one washer. After centering the blade & applying tension, now it takes just a very slight amount of adjustment for proper tracking.
This seemed the easiest for me to do. Mark Duginski authored a good book on tuning up the BS.
Re: Get the tension release too!
Ray Newman
>I thought 'bout the tension release, but I just don't saw w/ the BS enough to justify it. Probably 99% of my sawing is done on the TS.
What I've always done is just release the tension. I've done it for so long that it is now habit.
You are 100% right 'bout releasing the tension when done. An old time millwright told me if you don't, the cast iron frame will take a set.
