glue 5/6/07, 11:34 AM #1 Alex Alex Guest Info glueAlex>Hi,What is the best glue for gluing Purpleheart wood : Polyurethane (e.g. Elmers) or Caprenter glue (e.g. Titebond II)?Thank you.Alex
Re: glue 5/6/07, 11:41 AM #2 David Yoho David Yoho Member Offline 2,135 posts Info Registered: 1/5/04 Re: glueDavid Yoho>Good old Titebond II has worked well for me. No special prep, just apply the glue and clamp.David
Re: glue 5/6/07, 12:30 PM #3 Al Stokka Al Stokka Guest Info Re: Same here. Titebond II. No prep. Al Stokka - Cambridge, Iowa>
Re: glue 5/6/07, 12:33 PM #4 Stephen Shepherd in the State of Deseret Stephen Shepherd in the State of Deseret Guest Info Hide Glue of course Stephen Shepherd in the State of Deseret>
Re: glue 5/6/07, 10:47 PM #5 robert davis robert davis Member Offline 345 posts Info Registered: 1/28/05 titebond 11 robert davis>
Re: glue 5/6/07, 11:15 PM #6 alex alex Guest Info Re: titebond 11alex>Hi,So titebond II will be enough for Purpleheatwood (amarante). No need to use expensif Tropical Hardwood Epoxy Adhesive.Thank you!
