OT Old GE Gas Clothes Dryer
Fred West in West Chester, PA
>that now hums and will not start except occasionally and only when it does not hum. I have cleaned it thoroughly, replaced the old belt and idler and the drum is not binding. HELP!!!!!! Any thought from the vast collection of wisdom inherent on this board? :o) Shooting it is not an option and already strongly considered. :o) Thank you in advance. Fred
Re: OT Old GE Gas Clothes Dryer
Stephen in Frankfort KY
>If you hold the door switch in and give the drum a good push, will it start? If it does it is likely a bad motor.
Check the start capacitor, if the motor has one.
Gil Jones on Lake Seminole GA
It hums? Add lyric! *LINK*
Hoa Dinh
>Just kidding, Fred.
Follow the link below. The click on "It won't tumble." It tells you how to test the motor.
Good luck.
-- Hoa
WHAT IS WRONG WITH YOUR DRYER?
Re: It hums? Add lyric!
>Thank you all and I am unfortunately humming the lyric, NEW STINKIN MOTOR. :o) Truly, thank you all. Fred
Fred, That Dryer's Takin' You To The Cleaners
Start run plate bad Old GE Gas Clothes Dryer
del schisler
>their is a start run plate that probly bad Those motors if memory serves me right their is no cap. on those motors Just a start run plate
