>If I may I would like some more information from you all (excuse me, I am from Texas).
I need to repair some full extension drawer guides on my wife's desk. They are accuride guides and they are about 25 years old. The case cabinet side of the guide has separated from the roller bearings. --Does that make since? Is there a web site to check for instructions or should I just give up and buy a new set.
By the way, I really do appreciate your help. I have set up my shop and rewired two says with your help.
>Ken, it might well be easier and more practical to purchase new slides. However, it wouldn't hurt to check the link below to see what information you can turn up that might help you. There seems to be a pretty good FAQ section that might be helpful as well as the other links on the page.
>I'm trying to picture the problem, Ken. If I recall correctly, Accuride full extension slides from that era were "over-under" slides, weren't they? With two separate bearing races in two channels? They had a consumer-duty model with Delrin bearings (#4017?) and a similar model with steel bearings that was rated for heavier loads and longer service life. The ball bearings themselves were held in place by a thin sheet-metal stamping that kept them organized. If that has somehow come out, it's time to replace the slide, because those things are supposed to be captive in the channels. If they have come apart, it is either because of wear (more likely if you have Delrin bearings) or they have sustained a serious prying force for whatever reason.
Slides don't last forever, although with old commercial-duty Grants and Accurides, you should get at least 100,000 cycles out of them. We cycle-tested a slightly more recent version of that slide to almost 300,000 cycles without failure.
>Thanks for the info guys. The Accuride site was very informational. I, unfortunaly, decided to try to repair the slides by "popping" them together.................do you know how many ballbearings are in those things!!!
