Bandsaw blade alignment question
wilbur
>While tweaking my bandsaw today, as I was standing in the operator's position, I noticed that although my blade is square left and right, the back of the blade is not square front to back. From the side, it looks like the blade is tilted away from the operator. As a result, the bottom of the cut winds up being a little ahead of the top of the cut. This is highly annoying, since if I am not cutting completely through my board, I can't see how far into the cut I am.
I've been playing around with rechecking the coplanarity of my wheels (pretty close), and twiddling the upper wheel adjustment, but I can't completely get the blade square front and back. Is there something or an adjustment I'm overlooking?
Re: Bandsaw blade alignment question
Re: What bandsaw?
Re: What bandsaw?
wilbur
>My bandsaw is an old 16" Walker Turner. The basic controls and adjustments seem to be the same as any other bandsaw.
Re: What bandsaw?
Keith Newton
>Wilbur, you might check to see if you can shim under the table where it connects to the part that allows it to tilt. This may not be the adjustment that you are looking for, but it should do the trick.
Also see if you can move the top wheel out on the shaft a little, or the bottom one back. It may have something to do with the tracking of the blade relative to the tire crown.
Re: What bandsaw?
Jim Swank
>Check the blade guides also. In addition to the left and right side guides, there is often a back guide. Typically, the heel of the blade rides just off this guide and moves slightly backward into contact during a cut. The back guide, the tilt of the top wheel, and the width (depth) of the blade all interact.
Falberg saw Co
>It would probably be easier to re-orient the wheels on their respective shafts than to shim the table; but it's your machine..... When you re-orient you'll have to go back and re-align for co-planarity. Band saws are such a pain. I start with aligning the table to the frame and proceed from there. Wheels generally have more adjustability than tables. If you have a riser you might even want to take a closer look at the frame itself.
Try this
>I used to own that very saw for many years and it's a dandy. I doubt if your problem is with the table mounts. I suspect it has to do with the tires. Try backing the blade guides (upper and lower) totally away from the blade. Don't turn the saw on, but rotate the wheels/blade manually several revolutions and see if the blade is now square to the table in the front/back plane. If it isn't, check to see where the blade tracks on both wheels. If the tires are good and the wheel planarity is also within reason (check it at left, middle and right sides of the wheels), the blade should be tracking in the center of the tires, or at least that's where it tracked on my saw and it should be square to the table. If not, my advice would be to try new tires. If that doesn't work, then you might have to compensate by shimming the trunnion where it meets the underside of the table.
wilbur
>Could you explain more what you mean by reorient the wheel? My lower bandsaw wheel fits on a taper and has a key, so there's only one way that can go on the bandsaw. I haven't gotten the top wheel off yet to see hot that's fitted.
Re: Try this
wilbur
>Thanks for the suggestions. I've tried most of what you suggested already, with the exception of getting new tires. I've currently got a set of polyurethane tires that are only a few months old.
In any case, right now I've gotten the lower bandsaw wheel axle disassembled to see if there are any alignment issues, and to check on the bearings. Maybe when I get it back together it will magically fix the problem. :@)
Otherwise, I might be shimming the table.
Update: Bandsaw blade alignment question
wilbur
>Well, short of putting on new tires, since the ones I have are only a few months old, I've tried all the suggestions so far, and I still have the front to back tilt issue. It looks like I'm going to have to shim the table.
The new development is that this weekend I also came into possession of an original cast iron stand for this bandsaw! Currently my bandsaw is sitting on a homemade low wooden table. Maybe the new base will help align something.
Re: Update: Bandsaw blade alignment question
Alan S
>The pictures of Walker-Turner bandsaws I've seen look as if the frame is not divided so as to allow a riser block. If it is divided, that joint is another spot that could be adjusted and/or shimmed. John White's book "care and repair of shop machines" describes the process.
The way to tell whether it would be more desirable to shim there or the table is to consider the guidepost. You want your blade to be parallel to the guidepost, and the table to be perpendicular to that. The closer to parallel the blade is to the guidepost, the less you will need to readjust the guides when you raise or lower them.
If the thrust bearing remains the same distance from the back of the blade as you raise and lower it, adjusting the table is the way to go. If the distance changes substantially, shimming the wheels first (or the frame joint if there is one), could be a better idea.
