A Beading Tool
A Beading Tool
Alan Young
A Beading Tool
Alan Young
>I am working on a coffee table.
I glued up this apron before thinking through all the carving details that I would want-including a bead along the under side. I checked out purchasing a scratch tool but decided to make one. My prototype was made from a broom pole- really ugly but it sort of worked. I decided on modifications needed and then made a second from aluminum with oak handles.
I cut a slot in the aluminum to insert the cutter. But the rod I used was too slim(3/8") and it would bend when I tightened the set screw. So I attached a 1/4" brass bar to the back side. This makes it stiff enough when I tighten the set screw.
Here is the front:
The vertical aluminum blocks adjust for the thickness of the work piece. Here is the back:
I tried the tool out on a hard maple bench top.
Looks pretty good on the hard maple.
The mahogany on my coffee table should be a breeze!
-Alan
Re: A Beading Tool
Re: A Beading Tool
John McGaw
>I was going to ask you if you ran into problems with aluminum marking your wood as I have in the past but a close look at the photos seems to answer my question. I know that I'll never allow aluminum to rub against my stock any more. If I need a soft easy-to-work metal for a jig or tool from now on I'm using brass despite the cost.
Re: A Beading Tool
Alan Young
Yes It does .
Alan Young
>I am not concerned for the project at hand as the marks will be in an unseen area and will probably be sanded away. But If I like this tool well enough- I will remake it in brass.
-Alan
Re: A Beading Tool
Re: A Beading Tool
>What? So now you are a famous tool maker too? Aside from the aluminum issue it looks like a nice tool. It certainly looks like it is performing very well. Cool!
Tom
Re: A Beading Tool
Re: A Beading Tool
>Alan, this is not my "thing" so take my comments with a well intentioned grain of salt.
It seems to me it would be better if the stop block you have running along the top edge of the piece that sets the distance for the bead were a fence rather than a "finger". You were able to hold it steady on your practice piece, but if you swing the handles back and forth and don't keep the tool nearly perfectly vertical, your cutter will travel in a series of arcs rather than a straight line. Would a long slick fence make it easier to control?
Maybe posting this on the hand tool forum would be a good idea. (I�ve never been on the hand tool forum because my computer is electric and you have to have one of the kerosene powered ones to go there and to get good resolution for a picture like yours, they will all have to trim their wicks.) (Man, I hope the have a sense of humor, you don�t want those guys sneaking up on your, they all have very sharp chisels.)
Re: A Beading Tool
Alan Young
Yes to all your points Barry
Alan Young
>I did post this over on the Hand Tools Board. They are sending me responses hacked out on petrified rock. :^)
I suspect I will need to excersise restraint when running the beads on my table. I may explore a fence like stop. As John noted aluminum is not the optimum material but it was available and works well for
prototyping. A fence in brass would be pricey...Maybe back to wood for a fence.....
-Alan
Re: A Beading Tool
Re: A Beading Tool
Tom Stockton
>Alan
Sweet tool, If you got it anondized would that help keep it from marking the wood. probably cheaper than redoing it in brass.
Tom
Re: A Beading Tool
Re: Yes to all your points Barry
>I made one a long time ago out of wood. Very crude compared to yours. It was a block of wood with a rabbet in it and a slot for the blade. The blade was a piece of old band saw blade that I ground and honed. I wedged it into a slot in the block. It worked just long enough to do the job. Had not thought ot it in thirty years. Roy Underhill(?) would have been proud. I should have stored it in the museum of ancient technology.
Re: A Beading Tool
Re: Yes It does .
Al Stokka - Cambridge, Iowa
>I length of UHMW (ultrahigh molecular weight) polyethelene, self-adhesive tape would quickly and cheaply solve the marking problem.
Al
