Miter Saw Blades
Miter Saw Blades
Miter Saw Blades
Dan Clermont
>The time has come to replace my 10" Makita blade on my LS 1013
I have access to Freud, CMT and FS blades locally.
I bought home the Freud D1060S from HD yesterday and before I mount it on the saw thought I'd find out if anybody has anything good or bad to say about FS, CMT and Freud blades
Thanks
Dan C
Re: Miter Saw Blades
Nat Robison
>I have the Freud Diablo D1080X on my Miter Saw (purchased from HD for about $50). For my needs (not a pro woodworker), it's great and loads better than the 40-tooth Dewalt blade that came with the saw.
Dave Bair, Eaton Rapids, MI
>I have the 12" version of your Freud on my miter saw. On white oak (a very splintery wood), it'll leave a bit of fur if the oak is not tightly supported by a zero-clearance backing. Other woods, like cherry, birch ply and aspen, I get clean results without a tight backer. I do need to use a steady cut speed; if I plunge into the wood too quickly, I'll get a furry edge almost every time.
>Good Afternoon Dan,
I have the Freud as well as Forrest, and my results over time have been very acceptable. I don't own a CMT, but love their router bits. I'm sure what you bought will do fine.
George
Glenn Madsen near San Francisco
>I use a DeWalt 80T blade in my 12" saw. It's been resharpened three times, maybe four, and is getting ready to go again. Came from the Borg, would buy again.
I use FS blades extensively on my Unisaw. The local sharpening service sells them, and they seem extremely well done. I've got three of them, IIRC, one custom ground for cutting lap mitered keyways.
Sharp seems to be the most important part for my (serious hobby)use. The excellent local sharpening service seems to be the most important part of that.
Tom Stockton
>Dan,
My personal preference would be the FS or CMT but Frued makes a real decent blade for a good price and it should be much nicer than the original. As Glenn said sharp is the important factor sometimes a blade you think is crummy out of the box can be saved by having it shapened by a good saw shop.
Tom
Dan Clermont
>Hi Tom
I have had my current Makita blade sharpened at least a half dozen times and it is going to be the loaner blade
Thanks
Dan Clermont
Tom Stockton
>it's always good to have a blade around for cutting nail filled wood and other dodgey material.
Tom
The Makita's come with....
>... one of the best OEM blades available. Most people complain that their other saws come woth a mediocre blade but the Makita's come with really good blades. At least the 12" CMS do or did.
I also got a full kerf 12" red teflon blade for $100 which I use for hardwoods and it does a really good job.
I used the heck out of the original Makita thin-kerf blade and needed a new one in a hurry, so I grabbed a 12" Freud Diable at Lowes for about $45, not expecting too much.
I was pleasantly surprised. Not quite as good as the full kerf, but the Diablo exceeded my expectations. I thought the Diablo was their bottom end blade, and perhaps I have it backwards (my thoughts, that is, not the blade) but it really seems good for the money. I haven't used it that long so only time will tell if it lasts long.
Happy Woodworking!
Re: Miter Saw Blades *Update*
Dan Clermont
>I took my OEM Makita 10" blade into another sharpener who looked it over and concluded the other companyy that sharpened the blade must have assumed it was a 60 Tooth blade and forgot to sharpen 4 teeth!!!
He is gonna sharpen it for me and we'll see if it improves. He also had great prices on FS Tool blades if this doesn't work out
Cheers
Dan C
>Having all the teeth sharp should help a lot. But buy a FS Tools blade while you're there, and then you'll have an extra good one. Mine always needs work when I'm in the middle of an important project with the CMS.
