Wavy OSB
Wavy OSB
Wavy OSB
DocJim...Fayetteville, NY
>On a couple of our new Habitat houses the OSB sheathing is bulging outward between the studs (2x6, 24 on center). The OSB is still well nailed to the studs. The walls are insulated with blown in damp cellulose, allowed to dry at least 2 days before the drywall is hung. The drywall is not bulging.
These are the first two houses that are on slabs with radiant heat coils in the slab.
This is going to be a pita to fix. Does anybody have any ideas on what happened here and how it can be prevented?
TIA
Jim
Re: Wavy OSB
Re: Wavy OSB
Keith Newton
>If the insulation is wet with water, I think two days is too quick to have expected 6" of damp material to dry, especially this time of year with the likelihood of not having the heat of helping the drying process.
Did you check to see how dry or wet the insulation was?
The side toward the drywall was able to dry more than the underside toward the OSB.
Did you run your OSB vertical? I don't frame very often, but I normally run it with the grain horizontal. By running it this way, the studs are holding the cross-grain in alignment better than when it is with the 8' up and down.
It may straighten out when it dries out, but I wouldn't bet on it. You will just have to wait and see.
If I were you, I would ask your question over on breaktime. I am sure there are some pro's over there who have dealt with this before.
Thanks for your service to your community. I think HFH is a great organization.
Re: Wavy OSB
One other thing.
Keith Newton
>If you want to try to hold off, and see if drying it out takes care of the problem. I would suggest that you just turn the heat up as high as it will go whenever you can. Maybe the heat will speed the evaporation.
I know some will think that is crazy, that you should use the AC. But while the AC will condense the moisture out of the air, the cool air will not allow it to evaporate from the inside wall as quickly as the warm air will. Maybe heating it with a several dehumidifiers would work best.
