Delta 34-445 Contractors table saw dust collection
Chuck Lenz
>Yeah I know, here we go again, but after the first dust hood I built I got a second wind and went nuts, obsessed, etc. and built a different one. Ok I'm probably still a little obsessed, but anyway, this time I addressed the back of the cabinet also, it seems to be a big issue with alot of people.
Re: Delta 34-445 Contractors table saw dust collection
Chuck Lenz
Chuck Lenz
Chuck Lenz
>Chuck, I obsessed also, and I have a similar saw, an older Rockwell version. I have posted pictures of my solution which is much more complicated than yours. I made a chute that come up from below that is about 2" by 12" and bolts onto the same assembly that carries the shaft and blade. Mine is hinged and the outlet comes out the front of the saw so that the blast gate (with micro switch) is right at the switch for the saw. The hinge allows the mechanism to swing the full 45 degrees.
I really like yours. Much better looking, much easier to make, really nice job. I think I over thought it.
What I am wondering is how effective it is compared to mine. Mine is very effective at getting the dust from under the table. Probably over 99 percent. There is still some that comes off the top, but it reduces that dramatically also. (I know this because on those times I forget to open the blast gate, the way I know it is there is a plume off the top of the blade that is hugely reduced by opening the gate.) I am considering an over the blade pick up, but my shop is so small and crowded, I hate to introduce anther obstacle.
I wonder how we could tell what the relative effectiveness is of the two approaches?
Chuck Lenz
>Hi Barry, yours sounds like a blade shroud underneith. Can you get a full 45 degree tilt with it on ? Things get pretty tight on one side in my cabinet at a 45 degree tilt, I doubt I could of done it like you did. As far as comparing the two for efficiency, I'd bet they would be close. Tough call without them being side by side cutting the same material.
Chuck - Very Impressive - But One Question
Howard In Toronto
>HOW'D YA GET THE SAW THAT CLEAN??
Is it something you've lent to a museum??
Do you clean out it after every single cut??
WOW!!
Very impressive.
Howard
Re: Chuck - Very Impressive - But One Question
Chuck Lenz
>Hi Howard, The reason it's so clean is they are pictures right after putting it together. Trust me, I could get it cleaner yet by going after some light surface rust on the internal parts and the bolt heads on the stand. Don't tempt me.
Bruce, a MN Galoot
>Completely OT, but do you spend a lot of time at Roughrider Hardwood? If so, say hi to Dave Jensen for me.
Bruce Haugen, formerly of Bis.
Chuck Lenz
>Hi Bruce, I'm not sure what OT means. I don't go to Roughrider hardwoods much, but I have been there a few times when I was into repairing antique furniture and needed something like quartersawn white oak. The bussiness seems to be doing pretty good, last fall for the first time that I know of he put out a 70 page catalog of mostly hand tools.
>Chuck, thanks for the name "blade shroud". I have been struggling for a name.
Mine hangs straight down and then turns or angles to the right. At that point there is a hinge on the rectangular duct and then an extension into a two by ten end boot for ducts. the hinge allows the assembly to swing enough to avoid it crashing into the left leg at forty five and the right leg at ninety. The top of the shroud is angled down to the left to allow the shroud to pivot without hitting the under side of the table. I also made a removable top that covers the angled opening, leaving about a half inch wide slot for the blade. I also installed brushes hanging down under the table insert to confine the rest of the gap. A piece of inner tube from a tire serves as a flexible sleeve that seals the elbow.
This thing works very well, but I suspect your works very nearly the same and is certainly a lot better looking and simpler to install. I made two cardboard mockups and one out of steel sheeting and then replaced it with yet another version. Did not actually cost much, but a lot of head scratching.
Chuck Lenz
>That sounds interesting Barry. I'd like to see a picture of it someday. One of the toughest things to figure out for me was how to connect the ramp I put behind the blade. I wanted that in there solid so it would never have a chance of comeing in contact with the blade.
>I e-mailed you some pictures of mine, Did not have time to cut them down to size for Wood Central. Thanks for sharing your method.
OT = off topic
Al Stokka - Cambridge, Iowa
