OT: Major Faux Pas (long)
Ted Wong
>Last week our little Weber Smokey Joe Kettle came undone at the lid and the handle fell off. After serving us well for 12 years it was time to say goodbye and move on up in the world to a propane grill. After shopping around on the internet we decided on a Weber Genesis #320. I originally had the order going at Amazon but had to go somewhere before completing the order so I had SWMBO finish up the process. Turns out she decided to shop around alittle bit more and see if she could get it sooner (Amazon had a 5 week wait). She found a place that had a unit in stock and was able to ship immediately so she decided to order from them instead. Well we get the grill today and the shipping company dropped off a huge box on our driveway. When I get home I can hardly contain myself being the kid on the block with a new toy. I dig in right away and unpack everything and proceed to assemble it hoping to get burgers on within an hour or so. Assembly went really smooth and everything fit together well, great fit and finish. As I'm cleaning up and throwing out some bubble wrap I glance at the label on the box and it says "Natural Gas Grill". I felt like someone just slapped me across the face.
Now that I have assembled the unit and everything is alright as far as I can tell there is no way the seller is ever going to take it back and shipping is probably out of the question anyways. I thought about a flexible gas hose with quick-connects from the nearest gas pipe (45') but thought it would be too expensive. I called Weber to see if they had a natural gas / propane conversion kit available but was told they don't have one.
So should I live with this blunder, sell it and get a propane unit, run 45' of pipe through the attic and down the side of my house or ??? Anyone have any suggestions?
Re: OT: Major Faux Pas (long)
Howard Norman-Prescott, AZ
>I have never owned a grill that used natural gas but I used one many years ago for a couple of years while living in an apartment. Nice, not to have to worry about if the propane tank has enough in it to do the job at hand. If I were you I would seriously consider running the necessary pipe to use the grill on natural gas.
On the other side of the coin who make the mistake? Was it your wife in ordering or was it the vendor?
Howard
In many cases
Dan Donaldson
>They usually make different burner jets to convert back and forth between gas and propane. Does this grill have such a kit?
Call a propane supplier
Phil Joines Krum,TX
>They may have some jets that will work. You'd need a regulator anyway.
Re: Call a propane supplier
Paul Woolson
>Last night my propane ran out halfway through some chicken breasts.
If I were you, I'd strongly consider going the natural gas route.
Dan Manturi
>As far as I can recall, you should be able to get new jets somewhere, but if Weber makes it, I'd say they would know. I am surprised you cannot get a new burner. On the other hand, running a gas line (as long as you do not move the grill around) solves a problem as pointed out. I did have a propane grill hooked directly to my home tank and never had to worry about running out. Heck, you make save money in the long run. Consider running the line.
Dan
If I'm not mistaken...
Paul Woolson
>...an I very well may be, I was under the impression that the burners were the same. The only difference is in a valve that releases the gas into the burners. Propane and LNG have to run at different pressures.
Worth asking about, and again, I could be wrong about that.
Re: If I'm not mistaken...
Dan Manturi
>You are correct in my experience. When I had to convert a natural gas grill my uncle gave me to Propane, I went to a grill dealer and the change was restricted to the jets. The burner element was the same. In fact, replacement burners do not even include the jets. You may have to make an adjustment on the air baffles to get the correct mixture. Having said that, i am surprised that Weber could not help this gentleman. If it was a situation of changing jets, and the grill he got is capable of that, it would have been a no brainer for them to fix him up unless the grill has no conversion capability.....
Maybe a stop at a local store would reveal more.
Re: Natural Gas
>I can't believe they are jerking you around on what should be a simple conversion. Keep at it and you'll get it fixed.
You haven't mentioned it, but I'm assuming that the grill you bought is the moveable kind with wheels that works off a cart-mounted tank, yes? If so, you may have a bigger problem.
When I got a 10K generator as back-up power for my house, I got one that was "tri-fuel" and would run on gasoline, propane, or natural gas. The idea was to be able to run it for short needs on gasoline, but to be able to hook it up to our main house propane tank for longer operation over days if needed. The propane company said "Absolutely Not" unless it was anchored to a concrete pad and not moveable. Reason being if it rolled and broke a connection, we'd have a huge gas leak and likely explosion or fire. Same for a natural gas hook up. So, unless you're mounting this grill as a fixture or have a source for LNG by the small tankful, you've got a problem being able to use it at all unless you convert it to propane.
Good Luck
mm
Curly Smith
>If the supplier sent you what you ordered then I'd call the Weber Customer Service (1-800-446-1071) and
(a) explain what happened and see if you can swap parts with them or
(b) buy a conversion kit from them for around $50.
The other option for a conversion kit is a specialty grill shop that sells parts.
Grant Smith
>Suggest you get ahold of an owners manual for the propane version of your grill. Then compare the parts lists of both of them and order up the parts that are different.
Even my Weber Smokey mountain (charcoal) cooker came with a parts list...should be something Weber can help you with.
Regards, grant in Iowa
May be a question of liabililty
Lee Schierer - McKean, PA
>When my son lived in Arizona his house had an outside grill thar was hooked to the natural gas line that served the house. It took forever to grill anything, the grill had tiny flames even on hihg and produced very little heat. After calling nearly everyplace in Tucson, we fianlly located a guy that would work with us. It seems that propane uses a much smaller orifice for the gas. If you are a dealer, you can get replacement jets to convert units you install. However, they won't sell you one unless they install it and unless the grill was installed by them. They won't accept the risk (liability) of a DIY person doing something wrong and torching themselves or their house.
We finally got him to tell us when the hole size was in the NG orifices and we bought a drill at the local hardware to drill out the propane orifices to the larger size needed for natural gas. You also have to adjust the air mixture on the burner inlets. Once we drilled the jets and made the air adjustments the grill worked just fine.
Lee
Don in Central Illinois
>Years ago we moved from town, NG, to the country LP, and we just changed the orifice in our gas clothes dryer. Later, when we moved back to town, we just changed the orifice again. Can't see much difference between the dryer and the grill. The only difference, as one other already commented is the pressure of LP versus NG and the opening size in the orifice to make up the difference.
Natural gas rocks
Michael Dresdner
>I switched years ago after several instances of running out of propane while company was here. It is the best thing I ever did. Ran the lines myself with the guidance of a guild member who was a former gas line plumber. As for the comment from NJ about it having to be on a concrete slab, that is clearly not the case everywhere. I ran a line outside to a lever shut off and a quick disconnect, and the local authorities came out, inspected it, and passed it immediately. Yes, mine is on wheels. It was quick, easy, and cheaper than the conversion kit, and the gas is cheaper in the long run than propane. I would run the lines.
Re: Interesting . . .
>Michael,
I didn't check with the gas company (since I don't have natural gas available here) on the wheels/no-wheels issue. Nor did I check "code". The propane tank and all lines and fittings up to our foundation wall belong to the propane company, so maybe the prohibition is based on their corporate legal department's policy. Hmmm, now where have I heard THAT kind of thing before? |;-}}
I had a NG grill mounted stationary in my last house, but must use propane now. Maybe it was the grill, but I think the propane's hotter, and sears better than the natural.
Now, back to woodworking . . . . . ;
Pete Stahl
>Ted,
I have a Weber and bought the new burner and hose so I could go from the bottle to NG. Haven't hooked it up yet but I got it from Weber (this was a while ago). They sell your grill in either LP or NG so they should be able to sell you the part to convert it like they did for me. I sent them a email and got a quick response and all the info on how to order what I needed. Ask in you email who you could phone if you want to talk to someone who really know about the grills. They probably don't have a pre-made conversion kit but may be able to get you the parts you need.
Pete
Re: Conversion
>With our mobile population and the longevity of Weber Grills, I have to think that people convert these things back and forth all the time, and bet that Weber has a conversion kit prepackaged. I'm assuming that Ted got a retard on the phone and needs to call Weber again, asking for a supervisor, if necessary.
Since they sell this stuff in a box for homeowner assembly, there's no reason the needed parts already in inventory should not be readily available.
mm
