Formica unrolling
Howard
>I would like to purchase some 4 by 8ft sheets of thick, 1/16 inch, Formica laminate from a mail order source. They ship it rolled. I was wondering if I would have a problem flattening it out?
Thanks
Howard
Formica unrolling
Howard
Thanks
Howard
Re: Formica unrolling
Tom Stockton
>You won't have any problem at all formica is usually shipped from distributers rolled up in big boxes. it unrolls real easy, if you're worried just let it sit and flatten for 15 minutes.
Tom
Bruce Wrenn
>Laminate is usually shipped rolled. If it isn't unrolled for some time, unroll it and from the backside "iron it". I have some that has been rolled for a couple of years now. Last pieces I used, I ironed them flat.
Paul Cates - Henderson, KY
>Howard,
Do you have a link for your source of laminate?
Thanks.
>Howard, if you unroll the laminate within a few weeks or even months and let it "rest" a while (minutes or hours), you won't have any problem with the laminate.
Sometimes, the fun is in the unrolling. Be careful. It's like a coiled spring. Back in my cabinet shop day we got it regularly rolled up. Had string around it with a "pad" of cardboard under the string at the edge to prevent the string from cutting into the product. Occasionally the pad would drop out and the string would cut a huge gash in the edge of the sheet. Also, if you cut the string, the sheet can unroll quickly and cut you or damage itself or knock over stuff sitting around. I'm making this sound worse than it is, but just be ready. Have plenty of room and don't let it unroll by sliding against itself. It may scratch it self if it does.
You will be amazed...
Jim Dillon
>... as I was when the cardboard shipping box arrives and you think that a mistake has been made. I ordered 6 4x8 sheets and they were all rolled up in a single box that I would guess was 4 feet long (obviously) and maybe 10-12 inches wide. Yup, the order was correct and all 6 sheets were rolled up in the box. Anyway, I digress. Lay the sheets out flat and in a few days they will be fine. And as Barry said, be careful when you unwrap them as they are indeed tightly wound. And be careful not to damage the edges. Have fun.
Jim
Jerry Samsen
>Yes, please share your link. I've never found an on-line source for Formica or equivalent.
Re: Formica source
Howard
>Paul:
I ordered it from: http://www.specialtysupplies.com/
Howard
Re: Formica unrolling *LINK*
Jim Dillon
>Jerry (and Paul),
Yet another source for laminate (Wilsonart brand) is CabinetParts.com at the link below. Have had excellent service from them. And as Howard mentioned, SpecialitySupplies has a lot of router bits, adhesives, tools etc. dedicated to working with solid surface materials including laminates. Have had good service from them as well.
Oops, I made a mistake ...
Jim Dillon
>... on one of the web addresses I mentioned. I used specialtytools.com, and not specialtysupplies.com. Sorry for any inconvenience this might have caused.
Jim
Look Local
JackLane
>Howard
I've never ordered laminate from one of those mail order places but I'd imagine they charge a premium price plus shipping. You should check with your local cabinet shops to see where they buy their laminate. They may even offer to get it for you. I run a cabinet shop and buy it for people all the time. Also, most of these suppliers will deal with the public and will offer the added benefit of 'slitting' the laminate for you. My supplier charges $1 per 'slit'. That can be a big help and a time saver. Most of these suppliers will also stock certain patterns in vertical grade and post-form grade sheets in addition to the standard horizontal grade. Vertical grade is about 40% thinner than horizontal grade and post form grade is between the two. I used to know the thicknesses but forgot them.
You shouldn't have any problems unrolling your laminate. We unroll and stick it immediately all the time. I like to let the substrate and the laminate sit in the same room and equalize in temperature. Be carefull working with cold laminate. It will break before you know what's happened.
All the best
Jack
