Pressure Treated Dowel Source
Rick Van Schoick
>I'm looking for a source for a pressure treated 1 1/8" dowel to replace the rung on our swing set ladder. Can't find anything on the web. Woodcraft sells hardwood dowels in sizes other than what I need. Anybody know of a source for pressure treated dowels? Many thanks.
Rick
Re: Pressure Treated Dowel Source
Tom Dunlap in Atlanta
>Why not look into another species of decay resistant wood like white/burr/live oak, black locust, etc? All you need is a limb, a vise and a draw knife and you'll have one made up.
Curly Smith
>What Tom said, although I'd probably just run down to the big box store and get some 1 1/8" curtain rod.
If you really need PT dowels then I think you'll have to make them. The smallest PT "dowel" that I've seen is 2" and it's probably classified as a "pole". If you start with a PT 2x4 then either of these two methods should get you the dowel that you want:
Easy Dowels!
Router and Drill Dowel Making Jig
Again, I'd just buy a piece of curtain rod.
>How many do you need? What tools do you have?
You could make one in minutes. Take a piece of treated wood (or decay resistant wood) and make it into an octagon on a table saw and sand the corners off. Or whittle them and then sand.
You could turn them on on a lathe in a matter of minutes. Have a lathe or a buddy with one?
You could do it with a router or shaper with a round over bit and knock all four corners off an 1 1/8" stick of treated wood and either leave it slightly "square" or sand it closer to round.
Brian in SLO
>Another possibility would be to use some green post preservative on the dowels you have. Just brush it on thoroughly to soak and they should work. After all, it's meant as a preservative for posts that are being sunk into the ground. And you can get it at any BORG.
Rick Van Schoick
>Thanks for the ideas. I have located birch dowels. How weather resistant is birch? Thanks.
Steve Schoene
>Birch isn't wonderful. If you paint it, and keep it well painted, most woods could survive. If you are looking for naturally rot resistent woods, you might be able to find dowels in either walnut or mahogany, either of which would work well. If dowels were white oak that would work fine too, but I have never seen any sold as anything but just oak, so that would be a gamble. Red oak is not good at all for weathering.
Pete LaBelle
>How bout a piece of galvanized water pipe ? Should outlive the swing set and the kids.
Couple things
>With pressure treated wood you have a couple concerns: it's not very strong, and it probably isn't good for skin contact. The newer pressure-treating chemicals are better than the old arsenic formula, but why trust them.
About birch: In my experience, birch is terrible for use outside. When a birch tree dies, it rots to mulch in no time flat. Yellow birch is marginally better than other birches, but only marginally. That said, I made a swing set for our kids many years ago and used birch dowels and they held up for several years before I had to replace a couple due to breakage, not rot, although they were getting pretty punky on the outside.
If you have a 1 1/8" bullnose router bit, it will make perfect 1 1/8" dowels in two passes. If you don't, come on over and use mine. Bring a piece of mahogany or white oak or something durable.
Springtown, PA
