REAL MILK PAINT
OT Computer? WORD question
>I'm Running Windows XP home edition. My system has started to apply "upper case" to the next character after I press the shift key, whether I am holding the shift key or not. So if I just depress the shift key and let it go, the "command" remains in effect even after the key is released.
Is there a "dwell" function or something? I thought is was only happening in Word, but it happing here in the Message forum as well. How do I reset this?
Re: OT Computer? WORD question
Tim Caley - North Little Rock
>It sounds like you turned on what is called sticky keys. It is normally used for people with disabilities. Press the shift key 5 times in a row and you should get a window to come up to allow you to turn it off. Or you could go to Control Panel and select the Accessibility icon and unclick use sticky keys option.
Al Stokka - Cambridge, Iowa
>Start, Control Panel, Accessibilty Options. Keyboard tab. Sticky keys?
Thanks!
Jesse in New Mexico
>Thanks Barry for asking the question and thanks others for the answer!
My new computer was having that problem and I just thought the keyboard was defective! Woohoo!
Thanks, it worked.
>Thank you. That was a pita. I type poorly enough as it is.
I appreciate the help.
The knowledge available on Wood Central never ceases to amaze.
Barry
