THE WOODRAT IS BACK!
Cutting patterns in 5/4 stock
Tom Dunlap in Atlanta
>Right now I'm in the planning stages of a project and I'll be going into new territory so I'd like to get some insights.
5/4 white oak board and batten siding is going onto a shed/barn. In order to have some ventilation I want to cut out some holes in a decorative design. The holes can be about seven inches wide and the height proportional.
Some ideas for the pattern are geometrical shapes or simple leaf outlines. there are going to be 90 boards so this cutting process can't be too complicated.
The two ideas that I have is to use a saber saw to rough out the pattern and then use a router and pattern to clean up the cuts.
The other idea is to use just a router. What size/power router would be needed to cut through the 5/4 oak? What bit would be the best?
Thanks for any help,
Tom
Re: Cutting patterns in 5/4 stock
Al Killian
>I would rough it out with a saw. Then use a router with a pattern bit to follow a pattern that you tape to the board. Trying to cut out with only using the straight bit on the router will waste alot of wood and waste alot of time. You would have to slowy take shallow cuts untill you made it all the way thru.
Just about any size router will work, just go slow and take your time.
The patterns should be made out of 7/16" or 1/2" mdf. This will keep the bearing frome slipping of the pattern.
BIG job, Tom
>Whether you saber-saw or try to plunge rout these openings, it's going to be a huge job to do 90 such holes. In the old days when I had a big ol' Porter pin router in my shop, I would have made a pattern/sled for the boards and routed them through in about four bites with the pin router. If I had to do it now, I would find a local cabinet shop with a pin router or a CNC router and pay them to cut out these patterns. It all depends on what your time is worth to you.
Let us know what you work out.
Ellis Walentine, Host
Jesse in New Mexico
>If you could live with a real simple pattern, I have seen some nice cutouts made with a circle (forstner bit or hole saw) on top of two angled cuts going toward each other. Looks like the sun rising on top of a mountain. Good news is its just a saw and a drill.
Similarly, you could do diamonds with a saw.
Still another way to skin the cat would be to saw the pieces in half longwise, cut your pattern with a saw, smooth with a sander, and glue back together.
Charles Sharp
>I would look at a pattern using a combination of hole saws on the drill press. Something like a clover leaf or a large circle in the center with 4 smaller one that intersect.
