instructions for using wood dyes
Quebecnewf
>Any good pages of instructions on using wood dyes . Iam interested in dying some birch chests that I have built
Quebecnewf
Re: instructions for using wood dyes
>Good Evening Quebecnewf,
Books by Jeff Jewett, Bob Flexner, and Michael Dresner address aniline dyes. Its a good idea to do a sample piece first, as the final color and shade may need modification by concentrating, mixing the dye with another, or dilution, or a combination of the foregoing to get the perfect rendition your eye demands. As I said earlier, you can "erase" the dye by wiping the piece with household chlorine bleach. One last bit of knowledge: the dye looks awfuk after its dry. Add some shellac and watch the magic!
George
Robert R Clough - Thorncraft
>Right, George. And the instructions on the bottles/packages of dyes are quite succinct.
Instructions for using wood dyes - another method
nailshooter
>First, nice page Dave. Great info there along with the pics.
I saw that the point of it was to use the dye without a sprayer, but have you ever applied it with one?
I use my Fuji HVLP when I do refinishing, and it works great. I like the Behlen's Solarlux dyes as they are more colorfast than the transtints, and that means I can use them for doors, etc.
I am mixing the Solarlux by cutting it 75% with anhydrous alcohol and misting it on in about 4-5 coats with my smallest aircap. I put the coats on pretty thin, and spray from different angles and directions to make sure I don't get lap marks. This method will make the wood jump out with any grain pattern. I finished some really curly birch doors for a customer a while back and the effect was stunning as it made the surface of the door look like it was crushed velvet.
If you try it, make sure you use a teflon lined cup. Something in the stain/alcohol doesn't work well in the aluminum cup, and after an hour or so it will coat the inside of the cup with a hard substance.
Robert
Re: Instructions for using wood dyes - another met
Steve Schoene
>Nailshooter--
Do you have a source, or specific experience, for comparing the light fastness of various dyes? I have often wondered about that. TranTint literature brags about the metalic based dye being light fast, and of course SolarLux is saying something similar, but has been around a lot longer (at least as a brand, not necessarily as a formulation.)
(Hard to gauge tone in these messages--read this as a call for info, not as a challenge.)
Howard Norman-Prescott, AZ
>Dave, that is an interesting bit of information that you have there. I read it and then bookmarked it for future reference.
Howard
most test them
Michael Dresdner
>Most companies test their dyes for fading, typically in a QUV weatherometer or some moral equivalent. If you ask the company they usually have the information and often will share it. In many cases, if you get to the head of the lab, he or she will have tested not only their own but all their competitors.
Solarlux is offered by H. Behlen and is cut from dyes made by other RM suppliers. I believe Transtint is repackaged Ciba Geigy Irgasperse.
If it is important to know, contact me and I can put you in touch with Behlen's head formulator, or get the information for you. Generally, companies don't care to have specs like this aired to their competitors, but will help out a customer who has a legitimate need to know.
Dave Arbuckle, Plano, TX
>Hi, Robert. Thanks for the compliment on the little tutorial.
I have sprayed dye, but only on small objects. I think you have better gun control than I to get good even coating without lapping. :-)
I occasionally teach a class on staining, and would enjoy hearing the benefits you find from spraying. I know of a couple standard reasons, but always welcome more info from real world experience. I appreciate your application comments and especially the warning, and will pass them along if you don't mind.
Sorry for the long pause in replying, today was a dog at work, then lightning knocked out the internet at home.
Dave
A book review - and a long comment
nailshooter
>Dear all:
Imagine my surprise to see Mr. Dresdner's name attached to a post. His work has made my life so much easier...
I am a remodeling and repair contractor, and have had my own business for about 27 years. I started in the trades as a carpenter, and pretty much worked my way into being a full service contractor.
Over the years, one of the hardest trades for me to fill is finishing. The list of reasons why is long and ugly, but there is good money in finishing IF you can get it right. The learning curve to put on good finish is not too long; but the curve to be a great finisher, one that can spot problems, work out mistakes, and anticipate problems (like high humidity mix for lacquer) is long and steep.
I was always interesting in going farther with my finishing skills, something beyond rubbing on a stain and toner then sealing, but didn't know where to start. Then one day, the painter I had was in jail for he umpteenth time (once again, not his fault) and I was left with a set of cabinets that needed finishing in a kitchen. My guy was by the hour and I based my bid on that. But I had to sub out the job since he was in the can, and boy did I catch it in the shorts.
I was determined NOT to let that happen again. So to the bookstore I go to look around, expecting to find books on finishing like a Popular Mechanics type book, or a Time Life book. There were a lot of books out there, and some of the guys that were on the rack are still around.
I grabbed Mike's book to thumb through and see if it could help me. Did it.. the book stood out immediately. I knew enough to be dangerous, so I didn't need to read about the perils of using mineral spirits with latex, or to make sure I didn't drink paint, or how to use a roller. It is a great mix of basics and more advanced techniques that are explained so anyone can understand them.
Mike's book is on woodfinishing. >Oddly enough<, is called "The Woodfinishing Book" by Taunton. I bought that book back in '93(?) or so, and it was $25!! Worth every penny. It is a great overview of finishes, techniques for applications, some theory, and even a couple of amusing stories. The book gave me the feeling that "hey, I could do that!". I might have been overly ambitious at times, but that is part of that learning curve.
I absolutely cannot recommend that book enough. After I bought it, I read some parts over and over, and for a long time used it as a reference. The only thing that might make that book seem a little dated would be due to its age, all the pics are in black and white. Still, it would be a definite buy on my list.
I finish professionally and have now for years as part of my business. But there is still good stuff in that book to me, no matter if you are a starting or working on getting better. At one time Half Priced books had about 5 of them, and I bought all of them and gave them to my friends that just want to finish their projects. They really like the book, too.
I don't know if this book is still available or not, but it should be in the finishing book arsenal for anyone serious about finishing.
BTW, I have no relationship with Mike, his company, Taunton, etc.
Just a happy guy with a recommendation.
Robert
Comments on using wood dyes - long!
nailshooter
>Hi, Dave.
As I posted a little up the chain (a bried history of what I do), I am a contractor that does his own finishing. Speed, dash and accuracy are what I strive for all the time. I started using dyes because I simply could not wait for pigments stuff to dry.
As a background on that, I see myself as Dr. Frankenstein, always experimenting to see what I can and cannot do. On summer weekends it is not unusual for me to try out new tools, practice with the ones I have, mix up paint formulas, or to try out samples from suppliers.
Specifically concerning finishing, I don't always trust the manufacturers and their information except as starting points, as they work in labs, I work in the field. However, some of them do have good tech support and online MSDS sheets.
That being said, I ran into a rash of exterior doors that needed to be finished, and the doors would be opend to the elements, but NOT to sunlight. I had some time to play around with before my bids were due, so I decided to try some different stains and dyes, mixing, thinning and retarding as I went. I bought the dyes, and some of the newer waterbased stains. Oil based stains were omitted due to the longer drying times needed for the oils to cure out before sealing.
My criteria was 1) had to be sprayable and 2) had to dry quickly with no effect on the surface (read: raised grain). I looked for uniformity of absorbtion, color clarity and uniformity of color when finished.
The waterbased stains were not satisfactory at all. They raised the grain, looked muddy, and were pretty miserable in the end product. I didn't even open up all the cans, so my test time was cut a lot right off the bat.
That left Transtint and Behlen's. Both mixed easily and sprayed well out of my HVLP system. BUT... the transtint clearly said on the bottle it was not for exterior use! Ouch! I talked to the industrial finishing rep from Sherwyn Williams, and he put me in touch with someone I could talk about the TT product, and he wasn't impressed. I called Jeff Jewitt yup - he answers the phone sometimes!) and he told me that the warning was there for a reason. He should know, I think it's his product! So that only left me with Behlens.
The biggest knock on the dyes has always seemed to be that they fade, and fade quickly. I put a medium coat of dye on a piece of birch, and left it outside in the South Texas sun for about three months with a few coats of poly on it, and it looked just fine. So I bid the door jobs with the Behlens as my colorant, knowing I wouldn't have the finished work directly in the sun. I didn't really have any exposure (no pun intended).
At the same time, I talked with a door refinisher in Phoenix, and we were talking about how to "properly test" our choice of clear finishes. He has been doing only door refinishing for a while, so we both came to the same conclusions for testing. Use mother nature!
I decided to use a really non scientific test on the dye. I put Behlen's dark mahogany dye on a piece of birch ply, and sealed with 5 coats of poly conversion lacquer. I taped a piece of heavy plastic on one half, and took it up on the roof of my house and left it there. It made the whole summer (temps as high as 106, and over 102 for 29 days in a row), the wet and icy winter, and all the climate changes in between, laying exposed to full sun and weather. It was up there for about 14 months (before I remembered it) so I felt like it got a pretty good test on the dye for fading.
I am completely happy to say there was almost NO differnce in the color between the two halves. I was REALLY surprised. The uncovered portion was actually a little darker , and a little of the brightness had faded some. NOT MUCH. So that's how I got to Behlens.
With a lot more testing of that dye with my equipment, I have found that I can spray successive coats of the dye within about 15 mintues of each other to achieve the color I want when I thin before application. A full strength application of dye from a sprayer is difficult to control.
I started spraying my colorants mostly for speed, and I learned quickly that it was really easy to feather in light and dark places with a gun. It is tricky with dye as it does have that chalky, powedery look when it is dry, but you can sure see your highs and lows easily.
I worked out the 75% thin for myself, and your mileage may vary. But the thinned material does two things for me; it allows me to completely control the amount of material applied and the dry time, and it allows that feathering out. I worked on this technique for a while, and with another backyard professor I met on WoodWeb, we compared out results. Thinning and spraying thin coats is better for uniformity of color.
So the spraying the dye came about for speed and ease. It also made cleanup a snap. No dirty rags laying around to dispose of, no oily project to hope no one fooled with for a couple of days, and on and one. I spray the dyes for as many coats as I need, and I can clear coat the same day!
Some folks do not like spraying the dyes as they worry about the "vortex effect", material bounce back, etc. Since I spray with HVLP now (man was I sorry to see high pressure go away...)I don't worry about that. I spray with a little, tiny 1 mm aircap, and there is almost no bounce to worry about at all. I think if you try spraying colorants, you'll really like it.
To get what I wanted for test results, I wound up going down and buying several door skins at the builder rehab store, and took some masking tape and masked them in to test sections. That way I could practice in little test areas, not whole sheets or odd boards I had laying around. It gave me uniform test material, helping me get uniform results. I studiously wrote down every formula with a marker on the test areas so I would know what I did so I could duplicate the results.
I hope this helps you out. I have written pretty extensively on this subject and on other finishing matters on the rec.woodworking newsgroup. There are some other finishers there, too that really know their stuff.
If you want to take this off line, you can always get me at
thegarbagenailshooterthetrash@sbcglobal.net
Just take out "thegarbage" and "thetrash".
Robert L. Witte
Re: Gees, Michael, tell'm about the
Carol - Strawberry, AZ
>updated book. It has color pictures. He oughtta love it. :)
I do.
