Veritas - Innovation in Tools
Laminate over MDF
Laminate over MDF
Laminate over MDF
Dave MacLuskie
>I'm about ready to add the laminate (formica?) to the top of an MDF table. The top is 3/4" MDF with a second layer of 2" wide MDF strips glued on around the edges to give it the look of a 1.5" height. The plan is to put laminiate on the sides and top. Which should I apply first? My brain is thinking sides first, trim with the router, then add the top, final trim with the router. Is that the generally recommended order?
Re: Laminate over MDF
Correct
>Apply to the sides first. You can use a trim router, but I learned to do it with a belt sander in a sanding frame for a very fine line joint.
Note too, that since you're doing a table, I would not hesitate to laminate the underside as well with thin gauge backer sheeting. MDF is far more stable than wood or ply, however, in the application you describe, it may still warp over time if not laminated on the reverse. At the very least I would heavily seal the underside with a good film-forming material like lacquer or shellac.
mm
Re: Correct
Dave MacLuskie
>Thanks for the confirmation Mark. I hadn't thought about an undercoat, but I think I'll put a coat (or two) of shellac on the bottom. The table is fairly large (30"x78"). It's a sewing table (retractable sewing machine lift thing) so it'll be in doors all the time in a fairly stable environment.
Agree with the belt sander
Rick Christopherson
>It is critical that the edges are dead-flush before laminating the top, so it is best not to rely on a router bit for final flushing. Just be careful that you don't sand the substrate so much that the marks telegraph through the veneer.
Jesper, Denmark
Be aware of a little problem........
Jesper, Denmark
>I did this on a navigation table some years ago. Both the MDF and the Formica are impervious to the off-gassing of the solvents in the contact cement I used, so when the sun was shining on it some time later, the laminate lifted as the fumes expanded.
I had to re-laminate and solved the off-gassing by driling some relief holes in the MDF, so the fumes could get away.
Maybe just taking your time and waiting long enough for the contact cement to fully dry would also have been enough.
Jim Dillon
>Dave,
There are two basic approaches (maybe a lot more for all I know 8-)) to laminate work. One is to glue the laminate to the slightly oversize substrate, then cut with a good laminate blade both the laminate and substrate to final size; and the second approach is to cut the substrate to final size first, then glue the slightly oversize laminate to the substrate and trim the laminate with a router using a trim bit. Both will work fine although I generally use the first method. For your work, I would use the first method and make your tabletop (including the edging) slightly oversize in length and width, attach the top laminate, cut to final size, then add the laminate edging and trim with a router if needed. Just my 2 cents.
Jim
Re: Be aware of a little problem........
Keith Newton
>Jesper, I am not so sure that your assessment of what happened is quiet accurate.
A lot of people think that plastic laminate is more stable than it actually is. It will absorb moisture, and de-sorb it when it gets left in the hot sun. The air can absorb the moisture from it as the moisture evaporates.
Contact cement will soften with heat, but if the laminate is trying to shrink more than the glue can stretch from the shear force on such a thin glue line.
To illustrate my point, back in the early seventies, as a young carpenter, I was doing a commercial job, where the owner of a spa wanted a dark green marble laminate panels inside of some arches. They were about 6' w x 8' tall, so I ran the sheets with two 4' sheets across the 6' width. I laid it up with a nice tight line.
This was a western exposure, and by the second afternoon, there was a 1/2" space between the two sheets, after the Sun cooked off all of the moisture. That is about
1/16" shrinkage per foot of width. Needless to say, the edges curled up when the glue fatigued.
It would be easier to blame the glue for the failure were it not for the 1/2" gap to explain.
Dave MacLuskie
>Thanks for the alternate solution Jim. I, uh, had already cut the substrate before I asked the question, so that wasn't an option in this instance but I'll definitely keep it in mind for the inevitable future project.
