More Woodworking house work advice needed.
Mark Kauder, Phenix City, AL
>One of the projects on my mental list of home improvement projects for the last 12 years, has been the rebuild of our Pantry.
I call it a pantry, but I think in the original house plan it was a hot water heater closet. It is about 40'x40"x8'. Right now it has some narrow 8" shelves starting at shin level and going up to about 7'. The bottom is filled with potato bins, fridge packs of soda, etc.
I hate it.
About 3 months ago, Fine Homebuilding had an article (cover story I think), about building a cabinet with full extension slide shelves to put into such a place and then trimming it in place.
This is a perfect solution for me.
The current opening to this space is a standard 24"x80" door size (it currently has a bi-fold door. And if I built a cabinet to slide into it will be a much smaller space.
Now my question: Any reason that I could not cut the opening wider? It is not a weight bearing wall, and there is no power running in that wall (phone wire - yes).
Thanks
Mark
Re: More Woodworking house work advice needed.
Okay to open it up
>If there is no weight on that wall, you should be able to get rid of it with impunity. Just decide how wide you want your cabinet to be.
One little issue is the depth (40"). Odds are you will not be making three-foot deep drawers, so what are you going to do with the extra space (behind or in front of your new cabinet? Or are you going to shorten the side walls, too?
Ooh, quick inspiration for you... put a 40" wide by 24" deep cabinet at the rear of the 40" deep closet but let the walls of the cabinet come all the way to the front of the opening. Then make deep doors with shelving in them to take up some of the remaining space in front of your cabinet.
Have fun, whatever you do. Sounds like a good project.
Re: Okay to open it up
Ron Hildreth, Alta, Iowa
>Ellis has a good idea.
Here is what you might consider, too, in the photo below. This started out as a walk-in closet with sliding doors that kept coming off the track. Now it's two silde-out "pantrys" with two recycle centers below. Works great!
Ron in Iowa
>I agree with Ellis. You might want to first remove the plaster or drywall to the size of your new opening. Double check for wires etc. Then insert new studs to form the new opening. Then demo the old studs and header to the new ones.
Tom
>What�s on the other side of the wall? That is, what is behind the closet? Could you take the wall out on both sides and make a cabinets that opens both ways. Probably two separate cabinets, but they could both be about 20" deep or deeper, depending on the thickness of the walls. Or could you open one out sideways? Have a set of pull outs like Ron�s that come out the side from behind the other set.
Time to come out of the closet and think outside the box.
Joe Piotrowski - Chicago Burb's
>might be a nice place to make a hidden compartment behind the built in for storing valuable when you go on vacation. etc.
House work advice needed - Thanks
>Thanks to all for the advice, guys.
A correction - I was working from (rather faulty) memory on the dimentions. It is actually 37" wide, and only 27" deep.
Ron - The slide out setup is a great idea (and yours are great looking) - certainly a consideration.
Tommy - Your demolition idea is right along what I was thinking. Thanks.
Barry - The back wall is a hallway wall (weight bearing wall) covered with family pictures.
Joe - darn you - what a great idea for a secret compartment! Hmmmmmm
Ellis - Food for thought as well.
Thank you all - I love Woodcentral as a resource!!!!
Mark
More-More Woodworking house work advice needed.
>Okay guys,
Thoughts here: so regardless of what storage method I decide on....
The original article that got me thinking was based on building a finish grade plywood cabinet (essentially), sliding it into the pocket in the wall, and then triming it in. Alot to be said about doing that way, most of the mess stays in the shop, fine tune the drawer slides, etc, etc. But what about just framing in the pocket to the size of the opening, raising the floor, and lowering the ceiling, sheet rocking the interior, and then adding the pull out storage (in whatever shape), and then finishing it in?
I tend to lean toward the build a box in the shop, but.....
Mark
Re: More-More Woodworking house work advice needed
Glenn Madsen near San Francisco
>Your shopbuilt box will me MUCH more accurately square, plumb and vertical. The slides will work better, and you'll spend less time upside down, on your back, with your arm crooked in unnatural positions, adjusting things. DAMHIKT.
>My thoughts exactly.
Thanks,
Mark
